I am converting my Isuzu Vehicross to LS1 power right now. I know that sometime in the near future I am going to have the problem of needing some PCM/ECM/VCM... ok... CM (how's that) modifications. For the most part, I will need simply stuff like speedo calibration and probably tranny adjustment. I however want to shut off the downstream O2 sensors as one of them was damaged when the motor was removed from the donor car. I have a local speed shop that will do a lifetime unlimited LS1 Edit modification... but the price is $450! I'd rather spend the few extra bucks and own my own stuff if it will do what I want/need. I was also looking at AutoTap and found EFILive and liked the Virtual Dashboard that they offer... but when I found VCM Suite I was pleasantly surprised with the package inlcuding the scan tool too.
A couple questions that come to mind imediately...
1) Can I shut off down-stream O2s with VCM Suite?
2) Can I run the scan tool at ALL times? the reason I ask is that I have considered installing an LCD display in the dash cluster in place of the gauges (I will be installing one if not TWO PC's in the VX)... then if I was running VCM Suite's Digital Dash... I could have my gauges at all times... easily... as opposed to rewiring the stock cluster. Is this something that would be OK? Or is there some kind of risk by doing this?
My PC system I will be running was orginally going to be ONLY for media entertainment but figured I could make GOOD use of it as well. If running the scan tool all the time is ok, I think I will be doing this. This of course means I have to buy into the package... lemme know.
TTYL!
