Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: NGK AFX in lambda
    Oct 2010
    17
    NGK AFX in lambda
    How is everyone setting up their NGK AFX wideband to read in lambda and then setting up PID's for commanded lambda and lambda error?
    I tried setting up a custom user for EIO that should have provided lambda readings, but instead it still provided AFR when logging. This made the custom PID's unable to be used.
    I have the EIO setup at Volts/.7096 + 9.1 and then the sensor and units sets to lambda.
    Nov 2007
    Minnesota
    555
    Someone correct me if this stuff is wrong -
    Lambda From NGK AFX:
    Lambda Error:
    Commanded Lambda:
    2012 Chevy Cruze A6 1LT RS
    Formerly - 2004 GTO, 2002 Z28, 2007 Colorado, 2008 Silverado
    Nov 2007
    Minnesota
    555
    Btw, I don't know if it is just me, but if I use the .7096 + 9.1 for AFR, I get a reading of 11 AFR when my AFX unit is showing stoich...
    Feb 2006
    Canada
    1,963
    volts should be .7142 and 9 is the + value
    The display is programmed to read 14.57:1 as stoich. I just use that number and tune from there
    2000 Trans Am WS6
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    I actually use V/10.41 + 0.62. It spits out 1.000 lambda during the startup procedure. I basically trust the 0.62 to 1.1 range that NGK specifies.
    http://www.dsxtuning.com
    Just say no to bull s***.
    i was working on doing the samething. I have my AFX reading in my main table in lambda as an eio input. What is the best way with the 2.3 bata to set it up for commanded lambda. Also for a lambda err. historgram?
    Nov 2007
    Minnesota
    555
    Quote Originally Posted by eficalibrator View Post
    AFX Lambda = [ Volts / 10.37 ] + 0.618
    Greg, can you explain why your formula differs from the one DSteck and I use? Ours appears accurate to me when I log.
    Quote Originally Posted by afasttransam View Post
    Look at the screen shots I posted. You will see a custom Lambda Error parameter and a custom Commanded Lambda parameter.
    Pay close attention to how I have the Commanded Lambda setup. You need to use the stoich value that you input in to your tune to get lambda.
    Senior Tuner eficalibrator's Avatar
    Mar 2006
    Detroit
    1,025
    Quote Originally Posted by Gh0st View Post
    Rounding error. They're both really close. I just did mine by converting the min and max AFRs supported (9.0 and 16.0, respectively) to lambda (dividing by ECM's reference value of 14.56 for Indolene clear) and solving via y=mx+b.
    Nov 2007
    Minnesota
    555
    Thank you for the explanation, Greg. Glad to see you're still around
    Mar 2008
    St. Louis, MO
    4,860
    I used the lambda range they specified instead of AFR, seeing as how it originates off of lambda anyway.
    Mar 2006
    Detroit
    1,025
    Yeah, well I use an AFM1500 and LambdaPro with even wider ranges and more accuracy.
    I think we're both saying the same thing here and both answers are going to give the average enthusiast data that's closer than he is able to argue about given combustion instability and his ability to fine-tune beyond the equation's limitation.
    I am still working on getting mine set up. Other than my AFX being [AUX.20121] and my AFR set at 14.56 i have mine set up the exact same. When i connect it to my car i get unsupported parameter for my Commanded Lambda and my Lambda err. My AFX is set to EIO Input 1. Wonder if i should try it as EIO input 2
    party foul on me!!!!! i had put my command afr low res and not afr high res in my tables Everything working good now.. Thanks for the help
    Mar 2010
    227
    what about a histogram for lambda error? do you use lambda error for tunning the same way you do afr error in a histogram for tuning the ve table?
    1993 reef blue Mustang coupe
    Ls1 conversion
    1 7/8 cooks headers
    AFR 205 heads
    Fast 92/92 intake
    PAT G./ EPS Custom cam 230/234 .600”/.602” 112LSA +2 advance
    century Built 4l60e with Circle D 3500 converter
    4.11 gears
    Nov 2007
    Minnesota
    555
    Yes, throw AFR error out the window and just use your Lambda error. I provided screen shots of how mine is setup above.
    Mar 2011
    238
    Commanded Lambda:
    I have my Commanded Lambda function set up as 1/[PID.6010] or 1/equivalence ratio.
    Are there any significant differences between the two, besides mine automatically accounting for different stoichs?
    Nov 2007
    Minnesota
    555
    Quote Originally Posted by Beatdown Z View Post
    You want:
    commanded air fuel / stoich = lambda
    So in my example, if I commanded 12.1 my commanded lambda would be .85
    Your way should work too, but I've never used equivalence ratio. I'll try it because then I won't have to change my scanner settings when changing fuels.
    Dec 2008
    on the Dyno
    1,825
    I use EQ ratio because by definition it is just the inverse of lambda. I do this because I tune multiple vehicles that may have varying stoich settings based on where they are from and fuel being used. This saves me the trouble of having to go in and edit the custom PID for each different vehicle I tune with different fuel.
    Gotta watch out on some of the Gen4 stuff cause EQ=Lambda on some of them.
    Located in Central Kentucky
    ShorTuning
    Tuner in Training 346ci's Avatar
    Aug 2008
    37
    Just wondering, but why are you guys wanting to read lambda instead of afr?
    1998 Z-28: lid, full exhaust, 3600 stall, drag radials = 12.08@111mph
