Results 1 to 6 of 6
Thread: 6l80E transmission slip?
    Feb 2012
    Oil N Gas Territory
    15
    after installing a pro charger d1 65 lb injectors and setting fuel air and spark up on test drive the trans feels like it it slips, takes a long time to shift, and locks and unlocks converter irradically. Car has a precision industries 2500 stall. I did nothing to the trans setup need help and expaination why this occured
    Feb 2006
    Canada
    1,958
    If you have done nothing to trans settings, then I would say you are exceeding max torque and you need to adjust torque managemant tables.
    2000 Trans Am WS6
    Tuner in Training Longslyde's Avatar
    Jan 2012
    St. Cloud, Minnesota
    38
    Definitely need to adjust the Trans for the added torque. If it helps, I have my copy of the tuning school 6L80E tuning guide. If you're running a stock Trans this will definitely help. I have a full mod transmission now so my copy doesn't apply for me anymore. It is still available and I will sell it for $60 shipped. It is the lastest version 3.0.0.
    2017 GMC Sierra Crew Cab
    Forged 6.2L Flex Fuel Tuned
    Twin Turbo 13 PSI
    8L90E Transmission
    3.23 Gears
    Yes, it runs on E85 too and LOVES it! ;D
    Jun 2009
    202
    Quote Originally Posted by tricky1 View Post
    You need a good tune...
    11.49 @ 118 1.49 60' Bolt on 2010 IOM Camaro
    www.6l80etuning.com 6L80/90 Tuning
    Advanced Tuner Redline MS's Avatar
    Jun 2006
    New York- South Florida
    536
    Well if the engine isn't calibrated properly shifting will be all over. This meaning that if reported load is off due to improper MAF and VE cal, the trans doesn't how to properly calculate shift times and pressures.
    HT
    Full Service GM Late Model Performance Facility
    www.redline-motorsports.net
    Follow US on FACEBOOK!
    Follow us on Instagram! redline_motorsports
    Potential Tuner dlw42069's Avatar
    Aug 2011
    1
    Are you trying to sell this guide still?
    Quote Originally Posted by Longslyde View Post
    I'm having the same problem as mentioned above, seems like it slipping 2-3 drive shift in my d1 g8 gt. Please msg me if you are willing to sell your hand book. Thanks
