Results 21 to 40 of 41
Thread: reading air fuel
  1. #21
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    why not just post it?
    All im asking for is the year of your vehicle & a csv file(if you have access to that).
  2. #22
    Feb 2008
    20
    2006 STS-V, I'll see if my buddy with the 2006 STS-V and EFI Live can forward me his file.
  3. #23
    Feb 2008
    20
    or do you want my HPTuner lile?
  4. #24
    Feb 2008
    20
    2006 STS-V file
    Operating System: Windows XP
    Microsoft .NET: 1.1.4322.2407
    VCM Suite Product: VCM Scanner 2.2.0.0
    VCM Suite Key: E
    VCM Suite ID:
    Credits purchased: GM - 8 Ford - 0 Dodge - 0
    Credits used: GM - 2 Ford - 0 Dodge - 0
    Credits available: GM - 6 Ford - 0 Dodge - 0
    License slots available: 407
    Single Vehicles:
    86YNDPM06100EE1K - Cadillac STS (V8) 2006 - 2006 STS V
    ID:
    Date: 08/08/07
    Hardware: 121
    Firmware: 112
    Part Number: 6220
    Rom Status: 0 3F 0 81 0 1 0 FC FF
    SPI Info: 20 15 FF FF 4E 41 0 0
    Config: CC 88 0 0 0 40
    System Status: F7 0 0 0
    Comm. Status: 0 0 0 0 0
    On Time: 0:06:43.390, 6:43.390
    Type: Cadillac STS (V8) 2006
    VIN: 1G6
    VCM ID: 86YNDPM06100EE1K
    BCC:
    ECM Seg 1 ID: 12607783 [Editor]
    ECM Seg 2 ID: 12607793
    ECM Seg 3 ID: 12607791
    ECM Seg 4 ID: 12608816
    ECM Seg 5 ID: 12608565
    ECM Seg 6 ID: 12607784
    ECM Seg 7 ID: 12607443
    ECM Seg 8 ID: 12607786
    ECM Seed: 3E0E
  5. #25
    HP Tuners Support
    (foff667)
    28,268
    Quote Originally Posted by LITTLEELVISDAN
    I would like to see what EFI can log that your saying we cannot.
  6. #26
    Feb 2008
    20
    mainly reading the lambda o2 `sensor to display A/F ratio's instead of Mv readings.
  7. #27
    Apr 2003
    Almost 2000 feet.
    7,876
    Well since they are 4 wire sensors and not 5 wire they are standard o2 sensors.
    Here's the GM o2 sensor wiring diagram for the 06 STS-V.
    Attachment 10531
    Always Support Our Troops!
  8. #28
    HP Tuners Support
    (foff667)
    28,268
    Sounds like they are simply logging commanded eq ratio which in our software will probably show up in lambda for that pcm.
  9. #29
    Feb 2008
    20
    having 4 o2 sensors how do I tell HPT to look at the lambda ones? right now its looking at a Mv reading which tells me its looking at the standard ones
  10. #30
    Senior Tuner eficalibrator's Avatar
    Mar 2006
    Detroit
    1,023
    The older N/A Northstar engines with the Siemens controller (and Siemens calibration) used true wideband (5 wire) UEGOs. Specifically, a Bosch LSU4.x
    Technically, all "oxygen sensors" are also "lambda sensors". They don't really care what fuel you're buring, they just change their output depending on where you're at relative to stoichiometry. Narrowbands have a variable output voltage 0-1v, and UEGOs (widebands) have a variable current from the Nernst cell that may be either positive or negative, depending on whether you're rich or lean. If it's only a 4-wire connection, I would most likely consider it a narrow band HEGO, regardless of what somebody at a dealership or tech line says.
  11. #31
    HP Tuners Support
    (foff667)
    28,268
    EC Tune just explained that none of the 4 you have are wideband sensors and I've explained how to log lambda commanded afr.
  12. #32
    Feb 2008
    20
    my confusion is that other people have STS-V's and other tuning software and they are seeing real A/F ratios. 10.5 14.0 Etc. with no more than plugging in that same way I do. The last thing i want is yet another bung hole in my exhaust (giving me headaches at the dealer for modifying) just to get a true A/F ratio before hte Cat. There has to be a way to use Caddy's output to se this.
  13. #33
    Apr 2003
    Almost 2000 feet.
    7,876
    That's COMMANDED Air Fuel Ratio that you are seeing, not Actual Air Fuel Ratio. The stock o2's won't show you that, just whether you are rich or lean of stoch.
  14. #34
    Feb 2008
    20
    If not then a bung hole it is. How about the extra Tq nanny's that still reside in the ECM after we turn off all the tq options HPT is showing us? There still seems to be more in the car that in the HPT software engine or tranny..
  15. #35
    HP Tuners Support
    (foff667)
    28,268
    I feel like a newb but what are nanny's? There are probably over 5000 parameters in the pcm & a similar amount in the TCM, what we try to do is give you the parameters needed to tune the vehicle properly between the two. If there are more parameters you'd like to see or need feel free to post what your looking for in the feature request section and an explanation of why and include your hptuners scanner log showing the issue as well as your .hpt file used for the scan & we'll look into what we can add.
  16. #36
    Feb 2008
    20
    The STS-V being an automatic has Tq Nanny's in the software limiting the amound of power going to the rear wheels. To better explain it, when the tranny kicks down a gear or two under WOT it feels like the car shifts down a 1/2 gear for a couple of seconde then kicks the rest of the power ot the rear wheels. There are Tq limiters prohibiting you from dumping all the power to the rear wheels. I would like to remove them. BUT I do understand there is another format for requesting or working on functionality.
  17. #37
    Mar 2006
    Detroit
    1,023
    If you completely remove the torque limiters during gearshifts (while the trans is 1/2way engaged), be prepared to title your next post, "Anyone know a good trans builder for my STS-V?" You CANNOT apply full torque when the gears/clutches are not completely engaged and expect them to live as long as stock. GM is not stupid.
  18. #38
    Feb 2008
    20
    Not really what i was describing. Let me try again. when on the dyno in 4th gear holding about 2k rpm and then going WOT you get a tq limiter hesitation (dip or bog) for about 250 to 500 rpm's before you get a strong pull (full hp/tq) delivered to the rear. You can feel this on the dyno and on the street. You can also see it in the dyno graph.
  19. #39
    Oct 2023
    5
    Lmao
    Quote Originally Posted by Ruben2 View Post
    Just got HP tuners and did my first log today. I've never done tuning before.
    I'm trying to figure out if I'm running rich or lean.
    This might be dumb, but in the histogram I click on the air/fuel tab and it shows this chart. I'm assuming it's the RPMs going accross and something else going down. all the numbers logged onto the chart are between 63 and 961. I'm just wondering what these numbers are. I guess I thought it would just show me 12.8:1 or 14.6:1 or numbers like that for each RPM.
    I know this is an old post and your either an expert by now or you sold your interface! I'm really hoping for something to click but for now I still have that puzzled look, like wtf !
  20. #40
    Oct 2023
    5
    when does this get easier?
