First off, I have some logs but I can tell you whats happening. It is a FTI 2800 stall in a 08 G8 GT.
I stuck a solenoid up in my TCM. I replaced the module and when I was in there there was some black material in the oil and on the mag. I flushed everything and reflashed the TCM and trans worked great.
I started logging it and notice the trans was slipping with the converter locked. You could tell it was locking slip rpms went from around ~1100 rpm to 100 rpm. I went back and looked at the shops tune and the TCC apply rates, offset and slip tables were stock.
I changed the apply rates, the slip tables and offset. I then went out and relogged the car would slam the converter on (not what I want but trying things out.) Slip would go to 0 but around 40% throttle slip comes back 100 rpm's or so and the trans learns and applies max pressure 109.9 psi. Slip backs down but under anymore throttle it jumps up to 400 rpms.
I believe its the converter clutch due to the incorrect tune in the aftermarket converter but has anyone seen similair issues??
To be clear, I am running a stock trans tune with a 460 whp car. I have changed shift points and pressures a little bit but I have not changed torque management. I have upped the torque capability "" to allow the trans to do its thing but I am here for longevity of the unit not firm shifts.
