Results 1 to 9 of 9
Thread: What should 02's look like at idle and cruise
    Does anyone have a scan that they can post up with 02's working correctly, preferably with longtube headers.
    My car is an 05 GTO with Pacesetter longtubes.
    My 02's seem to be very stable for a few minutes, then it looks like a 9.5 earthquake rolled through. I'm trying to find out what is normal so that I can figure out why this is happening.
    2009 Crystal Red CTS-V A6
    Hennessey CAI, Hennessey 2.55 Upper
    2005 Phantom Black GTO M6
    All stock other than forged shortblock, braided clutch lines, and bushings. CAR IS FOR SALE For sale, $14,000, 65k miles.
    Having a shop build your car is like having a porn star screw your wife. Pick up a chiltons manual and a wrench and learn something.
    Sep 2008
    1,668
    What you're seeing is normal at warmed idle and cruise. When the car is first started, they will be stable while it is in open loop. Once the car warms up enough to go to closed loop, the O2 sensors will oscillate high and low, it's how the PCM maintains AFR at stoich. When you're at full throttle you should see them go to a high voltage again, but you really can't pick a specific number because they're not really the right sensor to monitor full throttle.
    What you really want to look at is not your O2's but your fuel trims...if they're split from each other, or very large percentages...then you either need tuning, or possible have some older worn out O2 sensors.
    2010 Camaro SS M6. Stock Bottom End, Heads/Cam/Intake/Headers/Exhaust.
    2005 Silverado RCSB. Forged 370 LQ9/Borg-Forced Inductions T6 S484/Jake's Stage 4 4L80E with D3 Brake/4WD.
    2023 Durango Hellcat
    I have closed loop and all fuel trims disabled for tuning, and the 02 sensors are a week old...
    If them occilating is normal cool, but should they read similar? There are times one will be reading 700-800mv and one less than 90mv.
    Dec 2011
    Clovis, CA
    374
    No, they will be different as the banks are different. Thats normal.
    Thanks,
    Dustin
    This is mine at idle, not sure if its normal behaviour or not but it seem to run ok.
    2010 GXP Maloo ute, LS3, 6L80E.
    MM heads, 240/252@50 solid cam, 12.75:1 compression, 4500 Dominator converter, 3.46 rears.
    Shooting for 10s eventually.
    And here are couple of highway cruise logs, one is low load cruise, the other is high load cruise, my car runs good so I think they are normal.
    Potential Tuner Monaro 383's Avatar
    Jan 2012
    Melbourne, Victoria, Australia
    9
    Here's a log of my VE ute i took today!!
    2002 CV8 Monaro, 383 Stroker, Crow Cam 243/247 Dur@50 594/598 Lift 112LC, CNC'd Heads 11.6 comp, FAST 102 Manifold and Throttle Body, 4L60E Fully Built 3500 Stall, 3.9 Diff Gears, 1" 3/4 Di Filippo's and dual 3" Exhaust
    Normal imo.
    AkNovaMan
    '99 Jaguar XJ8 turbocharged 6.0L 4L80e
    '99 B4C Police Camaro '96 9C1 Police Caprice
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Yep all looking pretty good. You should see the STFT logs I get with Injector Dynamics 1,000's. I had to disable the front O2 codes for "insufficient oscillation" because the injectors react so fast. :P
    618/618 motor
    906/862 spray
