I had the guys at hp do my segment swap just have a small problem. I dont no if its the tranny or could it be the tune. The 80e goes into limp mode as soon as the key is turned on when the fluid temp is cold. After fluid temp increases it will come out of limp mode and drive fine. Its kicking 2-3 shift code and tcc pwm code. Both solenoids are new any help thanks.
