Hi there I'm just in the process of wiring up my wideband. I want to wire it into the car as a permanant fixture.
I'm going to wire the Red 12v via a relay which should be fine.
I am also going to be using the Yellow signal wire and Brown Ground wire to connect to my Hp tuners pro. It says in the afx instructions when using the Analog output feature, to ground the brown analog signal ground to the same location as the 2 black wires. As well as connecting it the Hp tuners.
Would it be a good idea to ground all earths of the Afx to the engine block since this is the electronic earth for all other engine sensors or would this cause other issues ?
Or do you just connect the 12v red to a switched power via a relay. Then the black earths to a good body earth. ( my battery is in the rear on the car ) and the brown and yellow analog wires straight to the Hp tuners?
