Anyone done any tuning for a blown chiller application?
Thinking about installing a chiller for the H/E coolant in my '07 Escalade.
could you explain a little more? Meth injection on in intake side, or just a simple cryogenic burst to cool the ambient temperature in the intercooler?
Bader Norris
MEP Tuned
Telephone: +965-55446651
Email: [email protected]
...it'll be A/C driven on a Maggie system.
www.activeinterchiller.com is the type of system he was referring to. I have the same questions, specifically, the true manifold temp no longer is so correlated with any of the sensors available with the GenIV truck to tune for.
^^^ Has your IAT sensor been removed from the MAF and relocated to the supercharger as it should have been? If it has, then tune it like normal - the chiller is only going to keep temps 20 to 40 degrees cooler depending on the rest of the setup, so nothing seriously different in the tuning process...
~Greg Huggins~
you mite be able to throw a little more timing at it with the lower iat temps,, but when in full boost the temps climb pretty quick and with interchiller the recovery is much faster
