the videos are in order.
the reason for current order:
1) if you don't know the software you wont get anywhere
2) torque man, cot disable are settings that get changed and usually never adjusted again so best to get them out of the way and accounted for
3) kr is the weakness of the lnf/ldk/lhu series engines and thus before making the more fun changes must be covered so a tune can remain safe after changes are made.
4) boost is the fun stuff and where most people decide to call it quits. boost and afr net most of the power and after timing is kicked in most everything is set and done.
5) maf corrections are at the end because after all of the initial changes are made and determined kr safe you must then calibrate the maf reference tables to obtain correct fuel trims
this also skews the calculations for lb/min flow numbers and torque calculations.
the other note for maf cal's is that after every change is made the maf must be re-calibrated to verify the changes are accurate when the new trim values are acquired. (you make a change/adjust maf/the calculations are skewed properly/now the lb/min values are more accurate and able to verify if change while not on the dyno was good)
i have said it many times before....there is no replacement for paying for a day or two of dyno time to work every bug out of your tune. myself, i prefer to use solid state dyno's for covering a lot of the tune then dynamic dyno the next day to verify i have no hiccups while sweeping, then touch up with road dynamics imperfection corrections to finish.
