Results 1 to 18 of 18
Thread: Open Dump Wastegate
    Open Dump Wastegate
    Today was my first WOT run with my 402 TT 05 C6. I picked up lots of retard during the run, ~6 while timing was 10 to begin with.
    Could this be because of knock sensors picking up open dump wastegates noise as knock? Tune is 50% scaled and Knock sensor sensitivity was never touched.
    My wastegates and dumps are located right at the yellow circle below
    Aug 2010
    Detroit, MI
    935
    Doubt it. Typically takes something to actually be rattling on the block to induce false knock like that. Might look at your choice of plug, or other things that cause knocking..
    Dec 2009
    So MD
    132
    Suspect a fuel issue - insufficient pump, high injector duty cycle, or the tune.
    How about a log?
    No trouble here.
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Knock sensor thresholds are supposed to be changed to go along with your 50% scale. Make sure to disable BKR as well. This will rule out any false knock and real knock conditions can then be dealt with.
    618/618 motor
    906/862 spray
    Jun 2008
    Charleston, SC
    969
    what kit do you have?
    10deg of timimg seems really low.
    G-FORCE Motorsports
    1941 CR 129 Pearland TX 77581
    281-993-5451 PH 281-993-5421 FAX
    www.gforce-tx.com
    [email protected]
    PCM Tuner LSX and SCT <-> How Much Force Can You Take??
    2009 CTS-V 630 RWHP 10.90 @ 129mph
    Quote Originally Posted by smokeshow View Post
    Could be ! I'm using the NGK TR7 plugs.
    The reason I'm suspecting the WGs is that they freaked the $hit out of me. They are so loud that I had to let off
    I remember someone in other forums was describing it as if you run over a Harley Davidson Bike and it's stuck down there to the end of the run
    Quote Originally Posted by Roger Ramjet View Post
    How about a log?
    No trouble here.
    3 DW 301 in tank
    ~30% Injector duty
    This was the first WOT run so fuel was not perfect. It was ~13:1. Can this lead to ~6 KR? I'm planning to take that up to 11:1 and go from there. I'll be posting logs very soon once I take care of some oil leaks that I found after the run, Diff Shaft seals and some other small stuff
    Looking good
    Quote Originally Posted by IDRIVEAG8GT View Post
    Will do !
    Quote Originally Posted by carlrx7 View Post
    A Customized HP Performance Kit.
    Quote Originally Posted by Mike@G-Force View Post
    I know but I'm just playing safe since this is the first WOT I do.
    Jun 2008
    Charleston, SC
    969
    Quote Originally Posted by fe9_fe9 View Post
    Sweet!! pics if you have time!
    afr of 13 could be the culprit behind the knock
    Aug 2010
    Roswell, N.M.
    1,956
    30% INJDC?! You need to turn a fuel pump down or something before you wash the rings out of that motor with the spray pattern your injectors are giving you with that Duty Cycle. 55-60% is muey bueno.
    Then tune for 11.5 AFR in boost and 14.7 at cruise. I can convert that to Lambda should you prefer.
    Lean will cause knocking as will over rich. You're also going to pick up a fair amount of power.
    618/618 motor
    906/862 spray
    Jun 2008
    Charleston, SC
    969
    nothing wrong with 30% duty cycle.
    Aug 2010
    Roswell, N.M.
    1,956
    I slightly disagree. Injector open time should be more just because that's how they're designed to operate under high pressure situations. Theyre much harder to control (not trying to argue, this is just from my personal experience.)
    618/618 motor
    906/862 spray
    Tuner in Training SAM_69's Avatar
    Mar 2011
    Chicago.IL/Jeddah.ksa
    23
    13:1 AFR in a boosted car for sure can cause a huge amount of KR
    Good luck buddy
    EFI Tuning Specialist
    Chicago.IL
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    If they're shitty injectors, sure, they'll perform like garbage. If they're good dynamically matched injectors, it's fine.
    It is very possible that it's the wastegates. My buddy's twin turbo 427 2010 Camaro just fired up for the first time last night, and when we took it out to push some boost into it, it would max out the timing reduction from knock as soon as the wastegates would open. These wastegates are recirculated, but the exhaust is disconnected at the end of the downpipes right now, and the wastegates tie back in right before the end of the downpipe. The timing is pretty low and it's at about 11.8 on 9psi, and is still pulling 8* the second the gates open (and holds that timing out). I have to assume it's related to the gates and exhaust setup.
    http://www.dsxtuning.com
    Just say no to bull s***.
    So after hitting ~11.5 AFR and having meth running, no KR was noticed.
    So, Open Dump WGs are innocent
