Originally Posted by
seevi
The fellow who started this thread was asking for help tuning E85 fuel. Smacking his knuckles with the forum yard stick may not be the appropriate response here. Tuning is based on data input from your wideband O2 sensor which determines the mass ratio of air to fuel in the fuel you are burning (E85, E15, E10, Diesel#2, kerosine, Alcohol etc.) If you have the ability to convert your wideband controller to report Lambda, it will report a different Lambda number for each of those fuels based on its Stoichiometric combustion value. Using your tuning software to convert exhaust system data to a Lambda value to determine a correction value is a proven procedure.
Using the EQ in tunings: The equivalence ratio of a system is defined as the ratio of the fuel-to-oxidizer ratio to the stoichiometric fuel-to-oxidizer ratio. Once again, AFR raises its ugly head. You can't work without it!
