Results 1 to 9 of 9
Thread: Idle EKG...need help (tunes inside)
    Nov 2008
    Germany
    65
    Been VE tuning, the car runs good and trims are good when the EVAP purge connector is unplugged. I plugged the EVAP back in after getting most trims to +/-3...but now the trim are +6 to -6/???
    I couldn't get the idle to normalize either. I cut the over/underspeed spark and even tried OL idle in the 400 and 800rpm column...no change.
    Here's the logs/tune
    Nov 2008
    Germany
    65
    I cannot help with the idle but this is what I see, the TPS is very erratic @ idle. When you cruise it is fine.
    The idle TPS is erratic as hell even when the over/under speed timing is disabled.
    So I'm sure if you can figure out why that is you will idle correctly.
    If I were to guess @ the problem .......a dirty or defective TPS seonsor.
    Nov 2008
    Germany
    65
    Quote Originally Posted by ctd View Post
    TPS is new
    Nov 2008
    Germany
    65
    Latest log...I set PE 400,800 to 0% throttle, then to 1.00 (14.68) in those PE EQ ranges. I thought that fixed it. It idle great the first two or three stops, then back to the crazy ekg.
    I wonder if there is some way to fix position the blade to see if it will idle correctly or there is a mechanical issue......just thinking out loud.
    Nov 2008
    Germany
    65
    I've checked for air leaks and checked the TB...nothing found. Does 2.8g/sec at 600rpm sound normal for desired g/sec for a stock 5.3 silverado transplant? Seems real low to me.
    Nov 2008
    Germany
    65
    I upped the RAF and VE for the idle area. Here's how it looks now..
    Nov 2008
    Germany
    65
    Why is my desired airflow at idle only 2.3g/sec?
