I want to convert to E85 on my NA 442cid LS jet boat engine. I'm using an F-body 411 PCM. My plan is to change the scoich value to 9.7 and use EQ ratio (power enrichment) of 1.2 to set WOT at 8.08 afr (.83 lambda). I have purchased an AEM E85 gauge and WB which reads out in afr. It also has an analog output that I assume provides 0 -5V lambda data which I will record on my HP scanner. I'm thinking that the scanner will translate the data into afr gas values. What do I need to do to adjust the scanner to display 'lambda' or E85 afr values?
This engine has a very good SD tune for gas (VE tables are accurate) and I just want to convert to E85. Is this the proper approach or is there a better method to use?
THX
Asteroid
