Results 1 to 10 of 10
Thread: 3800 Scanner Issues
    Oct 2007
    20
    3800 Scanner Issues
    Guys I having a problem with the Scanner/Config files My Tuning computer died it was running Windows XP and was all set up and ran without any problems......so i bought a new Tuning Computer with Windows7 and having major issues.
    I am using Beta 2.23.576 if that matters
    In the scanner can not log the following
    Injector Pulse width bank 1
    MAP
    Calculated Cylinder Air
    They all report at "unsupported paramater".
    The Config file is below. I need the Calc Cyl Air for alot of the histograms
    2003 SSEi SUPERCHARGED
    WHP=Top 5 on Stock Cam chart
    Pullied, Intercooled, Stalled, Geared
    2014 Sierra Denali,
    Whipple Supercharged
    LT4 fueling
    Kooks LT's
    Corsa catback
    Dec 2009
    1,084
    Have you been connected to the vehicle to populate all the available pids?
    Oct 2007
    20
    Quote Originally Posted by planethax View Post
    Yup I have connected to the Car, logged a file, and then realized that the Paramaters were unsupported
    2014 Sierra Denali,
    LT4 fueling
    Kooks LT's
    Corsa catback
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Quote Originally Posted by 1993 sle View Post
    MAP
    You clearly are NOT logging injector pulse width bank 1 nor manifold air pressure in this config
    Oct 2007
    20
    Bill, I understand. I am trying to log them, and i cannot get them to display.
    In "insert parameters" I have the PID list, AUX input list and then User defined.
    The Inj bank 1, MAP and the Cyl Air do not show up in the PID List.
    How do i add them
    2014 Sierra Denali,
    LT4 fueling
    Kooks LT's
    Corsa catback
    HP Tuners Support
    (foff667)
    28,265
    Right click on an empty slot in the table display- insert pid
    Oct 2007
    20
    I add them to the spot, but when connected to the car, they become unsupported. I KNOW they worked before the computer switch. Is there something
    At the Bottom of the window for the PIDs it says
    SOURCE: AUX and Size 0 for the Cyl Air, Duty cycle ....but if I insert anything else it comes SOURCE: ECM Size 1?
    What is that about
    2014 Sierra Denali,
    LT4 fueling
    Kooks LT's
    Corsa catback
    HP Tuners Support
    (foff667)
    28,265
    Why are you trying to add then to the analog inputs portion of the table? Unless you are using an analog input ie your own sensor that you've added that has a 0-5v output(which I highly doubt).
    My advice would be to watch the demo's and read the help file over before going much farther and hurting something.
    Oct 2007
    20
    Bill, that is what im trying to figure out. I am not adding them to the Analog inputs, I am trying to add them as PIDs
    I need to Not have them as the User Defined, and i need them in the PID list. This happened when i switched to Beta, and Win7. I cant see them in the PID list. I need the setup as it was before when it worked perfect.
    2014 Sierra Denali,
    LT4 fueling
    Kooks LT's
    Corsa catback
    HP Tuners Support
    (foff667)
    28,265
    They are definitely there in the pid list.
