Shift after nitrouse shot!
Well guys i what do i have to do so i can make the truck shift at the comand rpm?
The truck on motor shifts good when i spray it 1>2 shifts good 2>3 it hit's the rev limiter, I lower the mph but didt work.
What can i do or the tranny its giving up?
Most of the time the transmission is unable to shift in time, you need to lower the MPH a little and also lower like 300 RPM to avoid hitting the limiter.
Sometimes the converter is not suitable for nitrous and it slips too much, which makes the engine trip the limiter.
The only downside is that the transmission will shift much sooner when not using nitrous
Install a shift kit if available for your transmission, it's good for faster shifts.
Did you tune the transmission? Did you log a nitrous run? It's also possible that the trans is slipping
I have a 3600k circle d converter, and yes the tranny its build with a shift kit.
