Thats how GM set the lower limit on pretty much any pcm since 2004. In our E38 & E40 custom operating systems we've modified the code to go down to around 160F.
so are you saying 192 is 160 with your operating system?
No I'm saying GM has a lower limit of 192 in the stock operating system. Nothing more.
If you want to check out the custom operating system simply apply it to the file and take a look. Doesn't cost any credits to apply it to the file. Only when you want to WRITE it to the pcm.
ok Bill help me please to lower it down
What problem are you trying to solve?
2014 Corvette, Z51, 3LT, 7-Speed, NPP, 2 tops, Exposed Carbon Fiber roof, FAY, Laguna Blue, Kalahari, Museum Delivery.
i wanna tune below the lowest degree shown there
and i notice below the lowest degree, fans are running on high speed
As stated, several times in this thread, you would need to apply the custom operating system under the os tab.
