Results 21 to 40 of 53
Thread: 1.4T Cruze/Sonic Tuning Thread - Where to begin
    Mar 2010
    Texas Hill Country
    3,299
    How does one log Pressure Ratio?
    boost/baro, make a user defined PID
    I count sheep in hex...
    Mar 2006
    Slinger WI
    157
    Been putzing some more today... i think i got NLS working for us manual guys. however im not certain which actual setting is what made it work or the combo... however here is what i did.
    Fuel tab, Cutoff/dfco, left scroll bar, i changed manual gear type to "NV" which probably really didnt need to change but it ignores the clutch pedal switch as defining "neutral" anymore.
    scroll down some more. Control method - use predicted torque set to disable, and immediate torque type then set to max range.
    Then moved NLS enable tps from 125% to 83% and went out testing.
    Now its pretty damn warm out again right now, so my timing looks a little low because of having the iat take it away. But attached is a log to see that NLS is working and indeed no longer dumping boost. I was a jack ass and backed my foot off the loud pedal for a split sec from the jolt into 3rd gear, but it does seem to work well!
    2007 Suburban - Slammed, Cammed, Geared and Stalled.
    Jun 2010
    Milwaukee, WI
    11
    I just purchased a new '12 Cruze. Looking forward to getting it tuned in. Thanks for the great info.
    I come from tuning s/c 3.8s so this will be slightly new.
    Mar 2006
    Slinger WI
    157
    Welcome fellow wisconsin citizen!
  6. #26
    May 2008
    13
    i cant wait till next weekend i should have a Cruze to tune thanks to all for imput once i play with this car ill have a little imput of things i find
    06 GTO BOOSTED 440CI Self Tuned
    09 COBALT SS S256,TREADSTONE IC and much more...Silverbullet08 Tuned!
  7. #27
    Jun 2010
    Milwaukee, WI
    11
    I am reading the help info on E78 tuning. Trying to see how you cabibrate the throttle position as it reads only 84% WOT and it reads that high even at 40-50% throttle. Idle is 20%.
    Below is a table I have modified a bit to get better throttle response and take some TM away. I started by multiplying 10% at a time.
  8. #28
    please be careful modifying this table, especially in the low pedal/mph areas.
    Please log the Desired ETC Position % and ETC Position %, not the TPS (SAE) PID. The TPS SAE PID is the % of 5V, which is not necessarily the same as WOT.
  9. #29
    28,268
    I think what Chris is trying to say is these tables can result in you not having control over what the ETC is doing if you modify these tables ie throttle still going while you're holding down the brakes
  10. #30
    Jun 2010
    Milwaukee, WI
    11
    Well I tried it out in a parking lot first. And it did accurate without hitting the gas when first doing a trial n error. No biggie just shut the car off at 5mph. Then modified it more to see hitting the gas no reaction when zero'd out. I have tweaked this down some since this pic. I raised it about 30% which this pic shows much more.
  11. #31
    Jun 2010
    Milwaukee, WI
    11
    Just a couple more noob questions...
    1. Wondering what I am doing wrong to read the LTFTs. They read fine on Gauge display but not the histogram.
    2. The boost graph I made doesn't seem accurate.
    (LTFT)
    (boost)
  12. #32
    you need to delete the bank 2 PIDs, the histograms average the two.
  13. #33
    Advanced Tuner silverbullet08's Avatar
    Dec 2009
    Houston, TX
    453
    Also looks like you are measuring absolute pressure on your boost pid. You need to subtract atmospheric from that.
    HP-Unlimited Tuning and Custom Fabrication
    Houston area performance parts dealer
    MD800 Mustang Dyno 713-560-3889 Taylor
    2016 Camaro A8 "shop car" FIRST 6th GEN CAMARO OVER 200mph IN THE MILE 203.5mph
  14. #34
    Jun 2010
    Milwaukee, WI
    11
    Quote Originally Posted by silverbullet08 View Post
    I have tried to figure this out but not able to see how I go about doing this.
    Under the custom histogram I made I see filter but do not know what to put there or if that is the correct place of doing so. Please excuse my beginning level of this.
  15. #35
    Dec 2008
    Nevada
    4,452
    Watch the lnf guides videos for custom histograms should help you out. U can find the link In my sig
  16. #36
    28,268
    Newest beta 2.23.707 or newer also adds MPID's for all E78 operating systems.
  17. #37
    Dec 2008
    Nevada
    4,452
    OoOOoO
  18. #38
    Tuner snowvette's Avatar
    Oct 2008
    Rockford Il.
    135
    I was just reading through this old thread and found this. Is it ok to zero these out?
    2007 Chevy Trailblazer SS AWD with boltons GP tuned
    2012 Chevy Cruze A6 LTZ RS Vermount Stade 0 tuned
  19. #39
    Oct 2011
    44
    Wanted to revive this since the Sonic is supported now....and I just bought one. :-)
    Anyone have a good starter file for MPG on a sonic turbo I can look at? Nothing in the repository....
    PM if you want.
    JC
  20. #40
    Dec 2008
    Nevada
    4,452
    Quote Originally Posted by snowvette View Post
    its a timing retard table.. if you make it zero no harm will be done. if you get kr in the areas the table has calculations for then you will either have to manually remove them from the main tables or re-enable that table.
