To give you a little background, after installing a built 4L60E, I cannot get the thing to respond to any changes in the tune dealing with the 2-3 shift. I suspect it is a pressure issue at WOT because the cars shifts perfectly at partial throttle. It will bang the rev limiter on the track before shifting, but on the street it will shift around 6000 rpms every time no matter when the shift is being commanded.
I have attached my tune and log file from a run I made on the street tonight. Note I am commanded the 2-3 shift to happen at 5200 rpms and 58 mph. I logged Force Motor (PCS) Line Pressure on this run. Does anybody know what these values should be? Should they match the Max Pressure on the Auto Shift Properties tab in the tune?
Any help is greatly appreciated.
