i attatched 2 logs. firts on i had closed loop off most of the time and the second i had it on. i was also playing with timing a little. my tuner had things way off and it would bog and pop horribly at 2000 to 2600 at part throttle. he added some timing and helped it alot. but if you watch my logs timing drops way off under a load. im afraid to just start adding timing but i think thats what it needs. :? i would apreciate any help you can give me. also it looks terribly lean in a few places.
