Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 66
Thread: injection angles
  1. #21
    Quote Originally Posted by projectlnf View Post
    i see and is that just if you are leaning out? main reason im asking is because i see alot of knock mid range.. but once i hit probably around 4500rpm or higher it goes away? and i have noticed that the fuel angle starts early down in those rpms? i was maybe thinking its fuel knock..
    Same story of my LNF, I am just sharing what I did that removed about 90% of my total knock. I repositioned my knock sensors so that the pig tail was at the 9'oclock position and knock went from 4-5 degrees to 1 - 2 in literally 2 or 3 cells compared to almost every damn cell I hit above idle.
  2. #22
    Jan 2009
    792
    Ok so my buddy rethought his calculations and realized there's no reason to divide by 2. He explained it to me and it actually made sense, so I'm trusting his formula, until somebody else tells us we're doing this totally wrong! (Which is quite possible.)
    So, these are the numbers I come up with at 7k rpm...
    6 m/s injects for 252 degrees
    8 m/s injects for 336*
    10 m/s injects for 420*
    Holy cr@p that changes things a little bit! That means if you start injecting at the stock 360* point, and your injection time is 6 m/s, at 7k rpm your injection will stop at 108* before TDC. If your ign timing is around 25*, that gives enough time for the fuel to fully atomize before the spark fires. This proves out in real life because we know 6 m/s runs great at 7k rpm.
    If your injection time is 8 m/s, start time is 360*, at 7k your stop time is now 24* BTDC. Hmmm, looks like we might be spraying fuel on our spark?
    If your injection time is 10 m/s, start time is still 360*, at 7k the stop time is 60 degrees AFTER TDC! So we've sprayed fuel all the way through our spark time, and down into the power stroke. How could it possibly run right? We know this in real world results because 10 m/s WILL result in massive injection window misfires.
    Even if you max out the injection angle table at 431*, a 10 m/s injection time will STILL have the injector closing at around 10*BTDC. Not too good if you're trying to run your ign timing at 25* BTDC huh? And we haven't even talked about what that effect that chamber pressure does to the injector fuel pressures. It's no wonder we're getting the high side pressures up around 3k psi for everything to work right. This also proves what we (or at least I) have known for a long time, E47 is the ONLY way to run an LNF. Not E10, and CERTAINLY not full E85.
    Lemme know if any of you guys see something wrong with these calculations. I'm no math expert, and some of this stuff is over my head. I'm more of a real world guy than a theorize and calculate guy! Most of these numbers are just proving out what we've been figuring out on the streets and dyno's anyway. At least it gives value to what we've already known or guessed was happening.
    BTW, I just did this log this morning, I thought I'd throw it on here to show why they're using EFR turbo's on the Indy cars...
    Look at the friggin boost line! It's damn near vertical! It looks like from when I went full throttle (pedal) to when it hit 28.5 psi took about 300 m/s. The throttle wasn't even fully open yet. I think it was over 25 psi when the throttle was only at 80 or 90%. What a crying shame that these turbos have been so hard to get. It would be so awesome to have dozens more of these on LNF's. Going from no boost to 30 psi in about half a second is pretty amazing.
  3. #23
    Advanced Tuner |V3nom|'s Avatar
    Apr 2009
    Denham Springs, LA
    418
    Quote Originally Posted by gmtech16450yz View Post
    what if e10 is all i have, am i just SOL?!?!?!
    2008 Sky RL
  4. #24
    Dec 2008
    Nevada
    4,452
    Precisely sol
  5. #25
    Jan 2009
    792
    Interesting study here...
    http://www.eurojournals.com/ejsr_25_2_05.pdf
    The study was done on Hydrogen fuel, but the data is very relevant to what we're talking about here. They mentioned the interaction between injection timing and ign timing, and the fact that power drops off significantly when it's injecting too close to the spark event. That's what we're seeing as "Injection window misfiring". Nice to see the efficiency differences other than getting too close to the spark event were not that big. I was wondering if keeping the injection time retarded closer to the spark event was better for mpg's, like around freeway cruise areas. There's so little fuel required at freeway cruise that the injection duration isn't an issue like it is at WOT. Anyone do a lot of freeway commuting that wants to experiment with injection angles and mpg? Dammit Tom (Iambroke) why did you sell that Cobalt?!!! Oh, that's right, you got a bad@ss Camaro instead.
  6. #26
    Dec 2008
    Nevada
    4,452
    to bad that camaro is not a v8 lnf twin turbo that would be beast
  7. #27
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    snip... Dammit Tom (Iambroke) why did you sell that Cobalt?!!! Oh, that's right, you got a bad@ss Camaro instead.
    Thought I quit lurking around here didncha? lol.
  8. #28
    Dec 2008
    Reading, PA
    352
    This has been another great read - thanks to all who contribute to threads like these!
    2013 Cruze Eco - CAI, Catless DP, Catless MP, ZZP FMIC, Ported Intake Manifold, Mild tune (17psi), best 43.5mpg, 175ftlbs (pid)
    2008 Solstice GXP - ZFR 6758, catless, AEM stage 1 water/methanol injection, Hahn Racecraft Intercooler, solo street race cat back, LE5 throttle body - 307whp on a dyno dynamics (stock turbo numbers), 100 octane EFR6758 numbers - 463whp/454wtq
  9. #29
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    474
    yeah thats all i have is e10... but i am spraying meth... lol thanks to everyone who has helped me out with this im going to try and do some testing with this.
    i kind of did the other day and i noticed when i get up high in rpm i miss fired because i had my injection angle to far forward.
    ericemir- i have had mine clocked at 9 oclock for around 2 months now so i dont know whats going on.. no miss fires but i get knock in a couple cylinders and then timing gets about 15* and it just vanishes immediately
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
  10. #30
    Jun 2012
    warrenton va
    474
    well i have been fooling around with these tables a bit and i have noticed when you advance your timing and you get a little bit of knock you can take the injection angle and make it sooner and it will get rid of most of the knock im still in the process of playing with these tables, im doing it little by little. and i did notice that the tables in the high rpm's DO NOT like to be adjusted it miss fires like crazy lol.
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
  11. #31
    This all sounds right to me. Dividing by 2 doesn't make any sense mathmatically unless you are using 720 degrees for your calculation (which you could also do).
  12. #32
    Apr 2009
    Denham Springs, LA
    418
    can the injection angles help with low-mid rpm knock? seems like i get knock just from driving around town. also when i rev it a little from a stop while idling it knocks like 1.4. can injection timing save the day?!
    2008 Sky RL
  13. #33
    Dec 2008
    Nevada
    4,452
    move it and find out
  14. #34
    Apr 2009
    Denham Springs, LA
    418
    ill have to try it out and see if it works.
    2008 Sky RL
  15. #35
    Apr 2009
    Denham Springs, LA
    418
    can anyone explain what each table in the fueling section is for? id like to start trying them out to work on a knock issue but the explanation that hpt gives for each is far from concisive. i have no idea what a hom or what its for lol.
    2008 Sky RL
  16. #36
    Apr 2009
    Denham Springs, LA
    418
    no answer? are there any books, software, etc that explain what this stuff is and how to use it?
    2008 Sky RL
  17. #37
    Apr 2009
    Denham Springs, LA
    418
    how about an explanation for each part individually.
    2008 Sky RL
  18. #38
    Jun 2012
    warrenton va
    474
    sorry i have been extremly busy with work.. but i just got back into tuning my lnf cuz i strated to see knock when it was colder outside but ill see what i can do with these injection angles and let ya know
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
  19. #39
    Jun 2012
    warrenton va
    474
    bringing this thread back!!
    wondering when hom double intake kicks in? anyone know??
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
  20. #40
    Jun 2012
    warrenton va
    474
    ok so i have got alot of mine moved now and it seems to pull waayyyy better with my cam adjustments and timing advance its crazy how hard this thing pulls up to redline and it just holds it and keeps going with it.
    No limit intake
    Straight pipe
    Studded
    EGR delete
    Self Tuned
    RDP Fuel sump
    8" lift
    35" tires
