Results 1 to 4 of 4
Thread: Wiring LC1 into '97 Corvette NOT using A/C switch or Pro EIO box?
    Oct 2006
    Atlanta, GA
    26
    Hey guys,
    Right now, my 1997 Corvette is using the A/C Pressure Switch as the LC1 wideband signal wire, but it's HOT outside and I need to do some logging and A/C would be nice to have while doing so! I know the '97 Corvette doesn't have an EGR system, but I read this post (shown below) on Corvette Forums and am now questioning if I can wire in the Innovate LC1 wideband using Pin 9 on the PCM:
    Originally Posted by 'VETTE PHASE View Post
    • The EGR wire is located at Pin 55 on the Blue connector of the PCM (NOTE: on the 97-98 Corvettes this will be Pin 9 on the Blue connector).
    Apr 2009
    613
    Just need to add the wire in at the pcm plug and enable egr in the tune. Then set up your custom pids. Tuning in extreme heat usually gets you no where though.....
    1997 Trans Am WS6 - LS1 swap - TR224 - Pacesetter Longtubes - Yank SS3600
    - 3.42 Moser 12 bolt - Wilwood Brakes - HP Tuners tuned - P1SC-1 Procharger
    Oct 2006
    Atlanta, GA
    26
    Quote Originally Posted by flame View Post
    On the '97 Corvette, do I need to add Pin 9 or Pin 55 or ???
    Apr 2009
    613
    Pin 9 on 97-98 pcm
