Originally Posted by
jpierro79
There?s a hptuners segment stating very specific about overwriting OS systems and writing different operating systems in different ecu?s especially writing e38 and e67 your going to spend more time chasing your tail unless you get the dealer to rewrite the ecu to its original state. The other issue is fuel pressure settings on e67. It could have variable pump turned on. My 2013 zl1 has e67 ecu so you might have the variable pump software in it. If you don?t find out your actual fuel pressure and if it?s not turned off your in for a whole lot of headaches. I doubt they wired in fpcm to 55 Chevy. Last is the maf re-enable under airflow/dynamic set real low cause this will really give you low throttle headaches cause a cammed car doesn?t have steady low rpm vacuum either. There?s a good reason gm set the maf rpm boundaries high. Low rpm is not anywhere near as accurate as a tuned VVE w map sensor. Basically speed density mode. Best of luck. I don?t like to tune cammed car as everyone is different and has it?s own headaches.
