Results 1 to 8 of 8
Thread: Gen IV injectors on Gen III
    Dec 2008
    Houston, Texas
    129
    Anybody ever swapped nnbs truck injectors into 99-06 trucks? The injectors I'm trying to swap are Delphi 12613412, there rating is 50lb injectors. I would like to know how to convert the injector data from Gen IV to work on the Gen III, any help is appreciated.
    Thanks, Roger
    Dec 2008
    Houston, Texas
    129
    Anybody?
    Tuner longboxdime's Avatar
    Sep 2011
    birthplace of GM- Flint, MI where the water is heavy
    64
    I did exactly what you want with the same injectors. I made my own table but I believe someone made an xls file called ls3 to ls1 injector. I found it on accident after I made mine, unfortunately. I have it bookmarked on my laptop at home. When I get out of work I can post it up for you.
    Dec 2008
    Houston, Texas
    129
    Thanks I'll appreciate that!
    Aug 2012
    Huntsville, AL
    122
    http://www.hptuners.com/forum/attach...7&d=1301152832
    That should let you download the xls file.
    Jason
    01 Camaro Z28 LS3 525hp Built 4l60e
    74 Camaro Z28 LT 355 fully forged roller with t56 4.56 gears
    Dec 2008
    Houston, Texas
    129
    Thanks!
    Aug 2012
    Huntsville, AL
    122
    No problem, my friend.
    Jason
    Advanced Tuner Screamn03's Avatar
    Feb 2004
    Vacaville, CA
    832
    Quote Originally Posted by kyphur View Post
    Link is now broken. Anybody have a copy of this? I want to put the 50lb '10-19 6.0 Flex Injectors in my '05 L59 Flex Suburban that has a LQ4. Thanks.
    EDIT: Search, imagine that:
    https://forum.hptuners.com/showthrea...-To-LS1-Format
    -Michael Rudolph-
    2003 Redfire Cobra
    Eaton Powered to a:
    11.301 @ 129 1.68 60' MT DRs
    11.85 @ 124 1.90 60' street tires
