Results 1 to 4 of 4
Thread: Cannot read/write VCM after abort!
    Sep 2012
    2
    I was trying to "write calibration only" and hit "write entire" by accident. Well long story short it started the process and I hit abort. Now it cannot connect with my VCM and car will not start. Engine turns over but noticed fuel pump does not turn on.
    I tried using a different scan tool I own and that also no longer connects to my PCM.
    Any ideas?? sorry I tried searching the forums but couldnt find my answer. If by chance this PCM is now screwed...I have another one that was previously programmed for my car that I was going to swap in tomorrow and see the results. Will I need to use more credits to write this other one if it already is programmed and has worked for my car?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,268
    Yeah you likely fried the pcm. What you can try is disconnect the battery in an attempt to reestablish comms(its really a last resort in this case) and try finishing the write entire.
    Sep 2012
    2
    Thanks for the quick response,
    I disconnected the battery tonight and I am going to let it sit overnight.
    Any idea if I can install my other one and if I need to pay more credits or will it be good to go?
    HP Tuners Support
    (foff667)
    28,268
    If you have the year/model license for the pcm in question you shouldn't need any additional credits. If you are doing single vcm licenses you would need to license the new vcm.
