i have a 4200 stall converter in my car, i also noticed my car does not like to be be stalled up for more than a couple seconds or above a certain rpm. it actually gave me a bit of a scare tonight at the track. I usually stall it up around 2500-3500rpm, but I decided to come up on the converter higher than usual (3800-3900rpm). Next thing you know, Im in 2nd gear and i had no 3rd or 4th gear. Scanned the car and it threw a P0502
i searched the error code P0502 and this is what i came up with-
Conditions For Running DTC P0502DTC will run under the following conditions:* DTCs P0101, P0102, P0103, P0107, P0108, P0122, P0123and P1810 are not present.* Transmission is not in Park or Neutral.* Throttle angle is greater than 12 percent (3.8L) orgreater than 15 percent (5.7L).* Engine vacuum is 0-31 In. Hg. (0-105 kPa).* Engine speed is greater than 3000 RPM.* Engine torque is 40-400 ft. lbs. (3.8L) or 30-400 ft.lbs. (5.7L).Conditions For Setting DTC P0502DTC will set under the following condition:* Transmission output speed is less than 150 RPM for2.5 seconds.
Action Taken By Control ModuleControl module performs the following actions if DTC is set:* Illuminates MIL.* Commands 2nd gear only.* Commands maximum line pressure.* Inhibits TCC engagement.
all of this stuff happened. I wanna know where or if theres a way to raise the time or rpm so i dont have this problem again. If i changed it to "no error reported" for the track, would this prevent it from happening again?
