Results 1 to 12 of 12
Thread: OK, we've got these three timing tables.
    Who has made the main, idle base, and coastdown spark tables all the same? I've had issues with jumping between timing tables at low speed causing a surge since the timing is quite different between the tables. From what I've read this seems to be a common occurance.
    The question that noone seems to be able to answer is what determines which table is being referenced and how to change that. Some have had luck with bringing the values of the tables closer to each other to reduce the amount of timing change when the ECU jumps between tables. I've use other aftermarket systems with only one main timing table that work just fine. You just adjust the timing values for idle and coastdown at the load/speed that the engine idles or coasts down at. Why not do that here? I mean do we really need completely seperate tables for idle and coastdown?
    Senior Tuner IDRIVEAG8GT's Avatar
    Aug 2010
    Roswell, N.M.
    1,956
    Each table should be set completely different. You especially need more timing in the main spark tables versus the idle cells to prevent this issue that way the car won't surge and your idle spark overspeed/underspeed tables work correctly.
    618/618 motor
    906/862 spray
    Quote Originally Posted by IDRIVEAG8GT View Post
    OK, I realize that you need less timing at idle for these reasons, but why not just adjust those cells in the table that the engine runs at when idling rather than a whole different table?
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    Because you can have loads when you're trying to take off from a stop, and if you're only running enough timing to idle, it won't have torque to move. If your coastdown spark is too high, the engine may not slow down.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Well for example, what I'm looking at is my engine idles at around .23-.26 g/cyl airmass at 950rpm. As soon as I touch the throttle, the airmass jumps up to .40 or more, so why not just set the timing cells at .28 g/cyl or less to the desired idle timing value and quicly ramp up above that airmass? Likewise, on coastdown, the airmass is less than it is at cruise. So why not just lower those values in the timing table that are referenced during the coastdown and leave the values at the higher airmass cells at the higher timing?
    Mar 2008
    St. Louis, MO
    4,859
    Try it and find out.
    OK.
    Do you know exactly what conditions cause the switch between the tables?
    Aug 2012
    Huntsville, AL
    122
    Just a quick question but is the coastdown spark you speak of the "idle adaptive spark control overspeed"?
    Jason
    01 Camaro Z28 LS3 525hp Built 4l60e
    74 Camaro Z28 LT 355 fully forged roller with t56 4.56 gears
    Mar 2008
    St. Louis, MO
    4,859
    No. Coastdown has its own table.
    Aug 2012
    Huntsville, AL
    122
    Ah, o.k. Don't have that in my setup apparently.
    Jason
    The Coastdown table is under "Idle Spark Advance".
    Well I seem to have accidentally fixed the timing fluctuation by calibrating the speedo.
    I was going to make a baseline datalog with the timing jumping and surging and then make changes to the timing tables as discussed above. But first, I calibrated the speedometer reading in the VCM using GPS. It was reading way lower speed than actual. After calibrating the speed, the timing is no longer jumping fluctuating like it was before under the same load/actual speed. I still feel a very light surge, but it is much better than before and the timing was very steady when the light surge was felt. I think most of the remaining surge is just due to the cam/large plenum intake.
    This indicates to me that the vehicle speed plays a large part into which timing table is being referenced.
    Can you adjust coastdown timing to get better mileage? If not I am trying to get better mileage does anybody know how.
