Is there a reason in the stock 4L65E tune that 2nd gear does not ever lock?
Is it because there is no need to lock a stock torque converter at those speeds, or is it because of longetivity purposes (as in locking the converter at low speeds causes more wear)?
I'm trying to tame a high rpm loose stall and wondering if it would be worth it to lock 2nd also? 1st and 2nd gears at low thorttle command high rpm (and I know that's what you get with a high rpm stall) but once I hit 3rd I have it lock early and it's pleasant to cruise around town like that.
