Cylinder air/airmass
Is the dynamic cylinder air PID in the scanner the same as the cylinder airmass in the spark tables?
Stall Saver
These tables indicate to the PCM when an impending stall condition is detected. The PCM has the ability to set the derivative RPM idle control system into action at a fast rate and disengage the AC clutch if a potential stall condition is detected.
- RPM - In Gear: Below this RPM at the current desired idle RPM in gear, stall saver strategy will be implemented.
- RPM - PN: Below this RPM at the current desired idle RPM in Park/Neutral, stall saver strategy will be implemented.
So, is this a riddle tongue twister designed to befuddle me? Does this tell me something or nothing? I think I'm looking at words I understand.
I think I am reading this as saying, "the chart across the top is rpms that it's supposed to be at but if it drops to the rpm's entered in the fields to use the stall saver scenario".
