wondering if somebody can take a look at my tune and see what mistake(s) i've made to cause this
4.8L with tsp 224 cam, and cai in a 01 jeep wranger hooked up to the jeep 5 speed
file is 02 silverado 4.8 manual trans
i did a rough ve tune < 4000 rpm (using aem wideband)
since then i've been maf tuning i've gotten my maf tune pretty close with the wideband (or so i thought) (haven't done any wot tuning yet)
so i figured i would turn stft's back on and re enable dfco (just for kicks as i can usually filter the data out anyway) and figured i would see how close i was with stft's
the issues that i see are my stft's are split (bank 2 is always leaner than bank 1 iirc) and they seam to be reading leaner than my aem wide band
the other issue is the knock retard that can creep in but i figured if i have some other issue i would deal with it first
o2 sensors are brand new denso my exhaust is 2010 camaro cast manifolds and a y pipe i built and i seriously doubt there are any leaks
narrow band sensors are 4-6" after manifolds aem wb is 4" after y-pipe
my only other thought was intake gaskets motor does have 110k on it
