Results 1 to 9 of 9
Thread: Interface questions
    Jun 2012
    Southeast Wisconsin
    24
    Interface questions
    I tried a search and emailed support, but figured I'd see if anyone on here has some answers.
    I have a 2003 VW Passat and I want to find out why my CEL is illuminated. Ross-Tech gives the option to download their Lite version, which is supposed to be able be used with "3rd party" interfaces. anyone had any success with this? I tried using the HP Scanner, but it says that it can't find the PCM
    Jimmy
    Jimmy
    2005 LLY 4x4 3500 DRW 4 door
    AFE 4" Exhaust, AFE Stage II Intake (w/ Bladerunner), HPTUNER software!
    2012 Keystone Raptor - 41ft 18k lbs
    multiple smaller toys/ trailers/ campers
    Dec 2009
    1,084
    The HPT interface will not work, non supported protocol
    With Ross Tech you will need a different interface.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,266
    We do not support any VW applications, try scanning a vehicle that is supported.
    Jun 2012
    Southeast Wisconsin
    24
    planethax - thank-you.
    @ Bill... I hope you're not being condescending with the later part of your answer... I have scanned my Chevy and a Dodge and it worked just fine... my intent was not to complain in any way about the performance of your product in it's intended, or unintended functions. I was simply asking if there was a way to utilize the hardware differently, and have found that when a little more detail is included with a question, answers are generally better.
    Jimmy
    HP Tuners Support
    (foff667)
    28,266
    Our hardware is ONLY compatible with our software and cannot be used as a passthrough device ie you cannot use someone elses software & our hardware.
    Jun 2012
    Southeast Wisconsin
    24
    OK, thank you sir, and as previously stated, I am not displeased in the slightest with what I've been able to do with it on my vehicle that it supports.
    Jimmy
    Have you tried to connect using the HPT scanner, I have been able to pull fault codes from a non supported ECU using the scanner as OBD2 is an industy standard required by law in the US, I found I was able to use it as a basic scanner and read SAE values as well as fault codes (athough you have to check the code as the HPT description may not be 100% correct for your vehicle).
    2010 GXP Maloo ute, LS3, 6L80E.
    MM heads, 240/252@50 solid cam, 12.75:1 compression, 4500 Dominator converter, 3.46 rears.
    Shooting for 10s eventually.
    Dec 2009
    1,084
    VW uses a protocol that is not supported by the HPT interface.
    Jun 2012
    Southeast Wisconsin
    24
    I appreciate the tip Xjas, and I too have been able to pull codes (like on my brothers '01 Ram 5.2). However, when connected to the VW, it says "no ecu found". My assumption is Planethax has researched this in the past and has educated himself enough to confidently state (twice now ) that it won't because of unsupported protocol (I, being uneducated in this manner don't really know what he means, other than "It won't work"). I'm gonna trust both he and Bill.
    Maybe sometime in the future
    Jimmy
