Page 1 of 2 12 LastLast
Results 1 to 20 of 40
Thread: GEN V LT1 !!!! here we go !
    Mar 2008
    Paris, France
    435
    http://www.corvetteonline.com/tech-s...-block-reveal/
    Q&A session: Computer codes will be hard to crack for those who want to hang power adders.
    BE READY !!!!
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    I'm more concerned about the fact that the aftermarket isn't ready for DI.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Mar 2008
    Paris, France
    435
    Di ?
    Mar 2008
    St. Louis, MO
    4,860
    Direct injection
    Advanced Tuner oakley6575's Avatar
    Aug 2011
    421
    Should be interesting
    2003 Chevy Silverado Daily Driver, 408 Iron Block,
    LS3 Heads/Intake, 231/239 114, 4L80e, Yank SST 3200.
    Advanced Tuner Dr. Nopps's Avatar
    Jan 2011
    I'm proudly a successfull stalker of an honor roll student!
    368
    Were you mainly refering to the availability of larger aftermarket DI style injectors? On that note I wonder how far along ID has come with DI. Suffice to say there will most likely be some A-hole out there selling "re-drilled" direct injectors also.
    Mar 2008
    St. Louis, MO
    4,860
    I know ID had talked about it but really can't speak towards progress. If the aftermarket wants to survive, they'll have to find a way. The whole industry is moving to DI.
    Aug 2010
    Detroit, MI
    936
    It's going to take a lot of capital to fund the R&D to jump-start the DI aftermarket. Not a lot of people have a surplus of cash laying around right now, unfortunately. It will slowly evolve, though.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,279
    Yeah, from my understanding this will be the start of the gen 5 pcm's as well as these will likely be using a new ecm line, now we just need to get our hands on one.
    Any idea if it will be a Delphi or Bosch PCM?
    Mar 2008
    St. Louis, MO
    4,860
    Will these be supported in 2.23?
    Dec 2008
    on the Dyno
    1,825
    From my understanding the DI at certain pressure is capable of 127lb/hr... that's plenty of fuel for most people I would think considering less fuel is wasted during exhaust events. Only time will tell though... I'm more importantly looking to see how hard it'd be to use those badass looking cyliner heads on an older engine with conventional injectors with the DI holes plugged....
    Located in Central Kentucky
    ShorTuning
    Jan 2007
    12
    Quote Originally Posted by LSxpwrdZ View Post
    To use those cylinder heads you would have to have the cam lobes swapped. They are backwards compared to Gen3-4.
    Apr 2006
    573
    some joker on tech was bragging that the ec was "uncrackable" for "your own good" hopefully hptuners and everyone else in the industry strap in and break this in record time.
    Feb 2008
    Sikeston, MO
    173
    The injectors flow 127.X lb/hr at 1,4XX pressure, if I remember right. They increase flow rate to over 2,200 PSI. So, long story short, only the most extreme cases are going to need to upgrade injectors.
    As for boost, the LTX on the tilt rig is twin turbocharged.
    Quote Originally Posted by GregRexAdams View Post
    I thought the turbo engine in the video on the tilt rig was a V6 not a V8?
    2010 GXP Maloo ute, LS3, 6L80E.
    MM heads, 240/252@50 solid cam, 12.75:1 compression, 4500 Dominator converter, 3.46 rears.
    Shooting for 10s eventually.
    Senior Tuner eficalibrator's Avatar
    Mar 2006
    Detroit
    1,030
    You guys are forgetting that the available injection window for DI is MUCH smaller than it is for port fuel. Port fuel injectors have the luxury of injecting pretty much any time and using up to 100% on-time to get the fuel in the charge. (We usually keep this to less than 80-90% duty cycle to protect the ECU's drivers though.)
    With DI, you have a much smaller window of opportunity to complete the fuel delivery. Added to that, the fuel requires some small amount of time to evaporate prior to combustion as well. This means that we now only have ~25% of the previous window available, so we NEED injectors that at almost 4x larger flow rate just to keep up. Part of this is accomplished with higher pressure, and part of it is the injectors themselves having greater flow rates.
    Oh by the way, the high pressure pump is also a big limiting factor on available fuel flow. These are neither cheap nor readily upgraded in the aftermarket due to the complexity of the ECU controls for them.
    I will not be the least bit surprised when people start running out of fuel delivery on these engines with significant modifications.
    Advanced Tuner Atomic's Avatar
    Jun 2008
    455
    Excellent point, didnt think of that. I wonder how hard it would be to add a second set of traditional port fuel injectors....would have to heavily modify the intake though, but Im getting way ahead of myself.
    Mar 2006
    Detroit
    1,030
    Not only do you need to modify the intake to physically install the injectors (and a rail, and a regulator), but you also need to accurately control the fuel mass delivered from them, and blend it smoothly with whatever is being delivered by the DI injectors.
    ...or we could go back to the dark ages and have random aux injector controllers doing their own thing apart from the ECU and HOPE that fueling is somewhere near some moving target...
    Advanced Tuner omega_5's Avatar
    Aug 2005
    Maidstone, SK
    466
    While I agree that the aftermarket isn't up to par with DI as it is for port injection, I don't think it's as far off as everyone thinks.
    While it's still considered by many to be "small shop hack" stuff, many of the LNF (Cobalt SS/TC) vendors have made decent advancements in trying to accommodate fueling, in the form of larger fuel pump lobes, and axillary fueling.
    Quote Originally Posted by eficalibrator View Post
    I see your concern. But as with all many situations, people will hack stuff together for more power, until something viable in the controls side is available. I can tell that it bothers you to know that it happens... but that's just how it is.
    I can see many people going the port fuel route until a fuel system upgrade is available.
    Not to say that there aren't accurate dual delivery systems. They do exist, but they aren't exactly economical for most applications.
    Tyler
