Resetting LTFT
Since HPT sucks up the entire OS and table data for every read, does resetting the LTFT get blown away when you re-flash the VCM? ie., do the LTFT's get stored with the bin file and write back to the VCM when flashing?
HP Tuners Owner
Re: Resetting LTFT
LTFT's are only reset if you do a "Rewrite Entire VCM" or "Rewrite VATS/Tunerlock/VIN". A normal "Write VCM" will not reset them.
VCM Scanner includes a "Reset Fuel Trims" as part of the VCM Controls capability, which allows you reset them anytime the key is on or engine is running.
Chris...
