http://www.dsxtuning.com
Just say no to bull s***.
in all honesty, the smell doesn't bother me, it's getting all the power that i can out of it, that's my ultimate goal by tweaking this final step.
advancing would make the injector fire sooner, IE when the exhaust valve is still open correct? or do i have it backwards.
The most hated, make the most power.
93 Ranger. 5.3 D1X. 1069hp.
What I have found is if you have positive overlap in your non-stock cam, you must ensure that the START of injection is after EVC, not the end of injection or the bulk of your fuel can still pass directly out the exhaust.
If you retard (move the injection later in the stroke) you add to the boundary or subtract from the adder tables.
Well stock at idle an LS2 it injects at 410*, the intake opens at 378*@.05 and with a 3.3ms injection that puts the start at 397*, 20* AFTER the intake opens so I'm not sure that is 100% true. But That was what I was asking, did you need that advance to make up for the RPMs?
In that example the start of the injection is right after the EVC thats why I added the 13.4. Positive overlap is one thing but more importantly is how the EVC changes relative to the stock location. in that example the EVC was 3* EARLIER than stock.
I THINK i understand everything except for the RPM tables so far.
2006 Holden Monaro I Phantom Black Metallic I Red I One of 416
L92/L76 I Streetsweeper HTR I SLP LT I LoudMouth 2
JHP V2 I Powdercoated Black 18s I Kyne Splitter
2001 GTP I Stock DD
pulling 20 from the ect table did the trick for the fuel smell. just need to either tweak the boundry off idle rpms, or the normal rpm tables to get the snap back in it.
it's actually becoming a lot clearer the more i mess with it
Here are my latest tables.
Better fuel economy and no more fuel smell.
Hope this helps.
Screw it. You guys have worked hard to figure it out.
Blue cells represent cells you can edit. For the Boundary, set it to the same number across the board. Crank Duration and Target EOI are values that are calculated.
In the table with ECT and RPM as axis labels, red cells mean you're ending EOI too early and will possibly fire while the exhaust valve is open. Green cells mean you're behind the exhaust valve closing. White means you're dead on. It is advised to use 0.006" lift values instead of 0.050" lift values.
Play with the blue cells to find your final values. I'd suggest not changing the boundary.
Also, note that pulsewidth is the fuel injector pulse width taken from the scanner plus the short pulse adder and voltage offset. You need to manually look these up. If your idle pulse is 1.0ms for example, go into your tune and look up the short pulse adder at 1.0ms. Add that to the pulse. Then, look at your battery voltage and MAP value. Go into the voltage offset and look that up, and add it to the pulse. 2.2ms is the final delivered pulse on my car with my ID1000s while idling at 800rpm.
I said there was nothing special. It's pretty simple and plain!
You are the man!
I thought you were logging pulse width through different RPM and setting the entire RPM table, I guess it only matters around idle.
2001 GTP I Stock DD
And I was thinking it might be more beneficial to get the lower ECT setup for cold start?
2013 ZL1 A6
I modify EOIT to clear the idle smell. I don't mess with colder sections because GM advanced it for a reason.
Like I said, I only use this for idle calcs.
Hey Dsteck
1: With a more advanced eoit timing at higher revs. Does that equate to more torque and power on the dyno.
2: The RPM table ends at 4096rpm. Does it carry that number over for all revs above that level Or revert to 0?
3: The L98 advances EOIT alot up top. Do you peg 520 across the board for the L98 motors also or leave the advanced table?
Thanks i advance
P.S. Thumbs up for sharing the spreadsheet. It will help alot of people!
thank you for caving in sir.
most certainly appreciated.
Please note I posted this to just help visualize when events happen. I don't have instructions on how to set EOIT for power/fuel economy/ending world hunger.
Yes, it takes the 4096 value and carries it.
618/618 motor
906/862 spray
