Results 1 to 16 of 16
Thread: Colorado weird half shift / TCC hickup @ 17-22MPH
    Advanced Tuner ProTools4's Avatar
    Mar 2006
    sunny So Cal
    292
    Got a weird deal I cant make sense of
    5.3 Colordo , Magnacharger , Doug's TriY headers
    Tune and combo is over a year old and worked great. *pre trans mods *
    Customer had the 4L6o style trans built buy a known good builder
    added in a mild stall Edge Racing small body torque converter to the mix
    Symptom
    has an additionl shift / hickup at light throttle @ 17-22 mph in 2nd gear
    in the data logger shows the TCC going into "Release Delay / FS"
    Despite the minimum lockup speed is set to 42 MPH
    Tune file, datalog, and config file attached
    Datalog shows issue at 3:01
    I'll take any help I can get
    NotoriouSS TAD
    DATLS7N 73' Datsun 620 LS7/HNC/TR6060/4.10/T2/2450lbs/603RWHP
    J5 - 96' Impala SS - 4700lb autocross machine
    Langston - 96' Caprice 9C1 Beater
    Rosie - 67' El Co - race truck w/ plates
    Wall-E - 21' Tesla Model 3P
    Mar 2006
    sunny So Cal
    292
    anyone?
    NotoriouSS TAD
    SouthTexas
    20
    Did you find a fix for this.. I have a 2012 Colorado 5.3 that does the same thing..mine is only bolt ons with cam..
    Mar 2006
    sunny So Cal
    292
    Quote Originally Posted by z28demon View Post
    When did the weirdness start for you?
    What did you do last?
    Going to work on it more today!
    anyone have any clues?
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    Did more work on this thing.
    if the 1-2 shift occors @ 13-21 MPH
    it 100% definatly drags the TCC for just a quick .5 seconds
    if the 1-2 shift is less than 13 or more than 21
    the TCC does not come on
    keep in mind I have all the TCC enable set at 318MPH across the table!
    when commanding / forcing the TCC / OFF in VCM controls
    a 13-21 MPH 1-2 shift will not drag the converter
    anyone have any insight to this?
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    no one else huh
    well seems like 36%insh TPS 1-2 shift at anything under 20 MPH
    ....Makes the TCC come on for a brief moment in 2nd gear...
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    worked like crazy on this issue
    over 20+ hours in the car looking at just the 1-2 shift
    anyone have any info to add?
    NotoriouSS TAD
    Advanced Tuner c.u's Avatar
    Jun 2010
    Eville, IN
    282
    Have you tried to set the shift speed about 2 to 3 mph from one tps to the next. Some thing like this.
    Mar 2006
    sunny So Cal
    292
    yes I tried a linear type of commanded shift MPH
    just like that...
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    c.u
    have you worked with a colorado?
    do you have any insite
    I'm all ears
    NotoriouSS TAD
    ok i've added 3 new PIDs to the scanner for this TCM OS only:
    - TCC Off Reason 1
    - TCC Off Reason 2
    - TCC Ramp Off Reason
    The values logged will just be numbers so they won't make any sense to you so please email a log to support. Hopefully they will give me some extra info about what's going on here.
    you need 2.23.851 or later (available tomorrow).
    Chris...
    I count sheep in hex...
    Mar 2006
    sunny So Cal
    292
    thank you so much Chris,
    I have set aside time to look at the truck Thursday the 7th
    I'll post data logs ASAP
    NotoriouSS TAD
    Mar 2006
    sunny So Cal
    292
    thank you thank you HPT Service for your hard work!
    the issue is and was resolved by a bin file tweak via HPT service!
    NotoriouSS TAD
    Nov 2009
    44
    What ever became the fix of this issue?
    I haven't made a million post's so im not a super tooner
    Feb 2014
    South shore MA
    Quote Originally Posted by Chris@HPTuners View Post
    - TCC Off Reason 1
    - TCC Off Reason 2
    Chris...
    I have a 2008 saab 9-7x that is doing the same thing!!! Can't figure it out for the life of me. Mine seems to be most likely when I am in 3rd gear under light throttle and I didn't come to a complete stop. Has there been any other developments with this problem? Anyone else experience it?
    I have the same TCM OS as the TBSS don't I? I'm surprised its not a more common problem.
    Dec 2019
    Added log picture.
    - TCC Off Reason 1
    - TCC Off Reason 2
    Chris...
    Back from the grave...
    I have a 2011 V8 Colorado and I too am experiencing this same issue. OP mentioned a bin file tweak to fix. How do I go about this process?
    I know of 1 other tuner that is also running into this issue with another V8 Colorado. Both after transmission builds.
