Results 1 to 6 of 6
Thread: zr1 map sensor on 436 ecu
    Jan 2007
    LOS ANGELES
    81
    Merry Christmas everyone
    Hey guys now for some reason on hptuners i cant put in a negative offset ??
    For the linear and offset i got the specs
    linear 312.50
    offset -11.25
    it wont take a negative -11.25 only positive ??
    anyone have any idea what it can be ...
    its a hpt custom 3 bar opertaing system
    12592618 converted to 1260058 3bar
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    You can't enter a negative number for the offset value in older PCMs. That's why I never use the LS9 sensor with older stuff.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Jan 2007
    LOS ANGELES
    81
    ok cool makes sense .... i tried to tune it out but it didnt work well i got weird problems running that sensor and wasted alot of gas lmao
    I installed the duramax sensor last night and put in 333.33 and 33.33 now i need to redo the ve table ... going to be fun...
    I heard that the duramax sensor was not really good in vac is that true ?
    How many people running that sensor any issues ?
    Thank you
    Jan 2007
    LOS ANGELES
    81
    I have the older and newer style duramax sensor ...
    I am assuming the newer one is better ?
    Jan 2014
    6
    Would have been so much more helpful to know that HP tuners can't do this. just machined the spacer spent 3 hours installing it, rewiring the harness.
    Running same #125 bosch sensor 3 bar. in a 2002 v6 4.3l ECU 0411
    Please tell me HP tuners has stepped up to solve this? I read earlier I needed an update to accept negative offsets. Running Version 2.24
    Mar 2008
    St. Louis, MO
    4,859
    Update your software. HPT allows a negative offset now.
