just as the title states, what happens with the charge temp vs. ect table and why would it ever need to be changed? I'm tuning a car that has all kinds of stuff changed in terms of the cranking ve (basically cut in half), all kinds of screwed up values in the idle airflow settings, a zeroed out throttle cracker, etc.
I've put most of the stuff back to values that are stock based on other cars that I have tuned. However, when I put the charge temp vs ect table back to stock the car runs insanely rich at idle. I haven't tried to drive it, but its so rich that the short terms can't even get it in check....turn the trims off and it tries to idle at about 10:1 afr. If I put the table back to where it was the car runs fine for the most part.
The reason I'm still tuning the car is the fact that it starts up lean. On a hot start, it pegs my wideband at 16:1 but it starts pretty good. After maybe one minute when the fuel trims come on its fine....and if anything it will trim out a bit of fuel to maintain 14.7 afr. On a cold start, it doesn't always fire up the first try but it will fire up the second try and I never have to help it by giving it throttle. When cold, the afr registers but its still about 2 points leaner than commanded....if it commands 12:1 the car will be in the 14:1 range.
My quest to fix this issue led me to find the screwed up charge temp vs. ect table. With that table under cranking airflow, I can't understand how it affects the car while running?
On a hot start, the value in that table is 32 @ 194 degrees. A stock table has 19.1 in that cell. Whats really crazy is that in the 176 cell the current value is 0. The compare file has a value of 18.8....
I had a lot of trouble getting the car to lean up in the decel regions, but playing with the "min fuel milligrams" seems to have solved that issue. The car has 42 lb delphi/racetronix injectors.
Sigmon 18 is the tune with the screwed up values that runs, the final throttle cracker file is a compare file from a different car I tuned a while back.
Any help with my issues or insight on how the "charge temp vs. ect" table could change how the car runs long after it has fired would be much appreciated!
