does anyone know if i can flash my 2004 commodore pcm with a 2004 pontiac GTO using my enhancedd i/o cable which i bought for my 2004 vy ss ute. if i can right the pcm will i be able to read it again with my cable
thanks
thanks
04 VY Commodore ute M6 ls1, 918 valve springs, TR6 plugs, genttrbb twin turbo kit, 60lb seimiens injectors, Bosh 044 fuel pump, SX fuel reg, PLX wideband,Full Castle Hill Exhaust with 2 1/2in dump pipes, 4in cats into twin 3in cat back (no merge), Ripshift, oz700 clutch and 3.73 diff gears
My guess is no. You will have to purchase the GTO model to be able to read the bin file. They are two different vehicle types. Unless of course you bought the hardware this week and got two vehicle types for your std package.
Brian
the PCMs are different between the GTO and the VY dunnydoor...
if it were possible you would need the license for the GTO. Whats wrong with using your VY prog? GTO engine is a lot differnt than the LS1 in the VY (cam etc.)
I count sheep in hex...
