Recently my 2000 SS Camaro has developed problem where it loses power and cuts out above 4500 RPM when trying to get to 6500 RPM redline. I replaced plugs, plug wires, air filter, and crank sensor last week and still have the problem.
Since we do not have fluctuating MAP readings when this occurs we are pretty certain the valves are not floating.
I installed a Racetronix Fuel Pump Kit about 6 months ago and it ran fine with the existing injectors (36 lb/hr) where my motor has about 520 hp at the flywheel (383 LS6 stroker).
Two days ago we strapped a fuel guage to the windshield and it turns out fuel pressure drops from 60 psi to 55 psi at WOT.
My car has the fuel pressure regulator in the gas tank with the fuel pump assembly instead of a return line from engine compartment.
My question is whether or not this drop in fuel pressure is to be expected or if this means the pump is not performing correctly?
I did not test pressure at WOT when the pump was new, only after the high RPM issues began recently.
Thanks, Jim
