Results 1 to 12 of 12
Thread: 04 gto 4l80
    Feb 2013
    3
    04 gto 4l80
    Tuning 04 gto for 4l80 possible changing OS?
    Aug 2006
    5BA8
    3,295
    Quote Originally Posted by Nosboy89 View Post
    What?
    EFI specialist
    email=[email protected]
    Feb 2013
    3
    I have a 04 gto with 4l60 spear tech conversion plug looking to program my trans can I use a data file from a truck to make it work
    Like a segment swap
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    Like a segment swap
    The 2004 GTO used OS 12587604 ... this OS was unique to the GTO, therefore no compatible 4L80 segment (i.e. same OS) exists to facilitate the swap.
    Aug 2006
    5BA8
    3,295
    You still should be able to program it, just as you'd program the 60. What do you need to do that you can't do by programming it the way it is?
    EFI specialist
    Feb 2013
    3
    Wouldn't the OS be similar in 04 looks like the express and savanah van had a cable ls 4l80 combo so possible segment swap?
    Dec 2009
    1,084
    Quote Originally Posted by Shrek View Post
    Senior Tuner Frost's Avatar
    Jan 2006
    Richmond VA
    1,950
    The Speartech harness supports the traditional segment swap. Wiring to use the 60 segment adds a few relays and a little more. That's a different conversion harness than the one he bought (unless Speartech makes two versions now; he didn't use to).
    Steve Williams
    TunedbyFrost.com
    Aug 2006
    5BA8
    3,295
    Quote Originally Posted by Frost View Post
    Yeah, I was thinkin he had the conversion harness to run a 80 without doing the segment swap. He's got the pigtail to pin into the PCM connector.
    EFI specialist
    Aug 2006
    Oak Forest, Ill.
    36
    Here you go.
    Jeff
    98 GMC Twin Turbo 5.0, 4L80e, Moser 60, 4:10s,
    Aug 2006
    Oak Forest, Ill.
    36
    Hhmmm, I just tried to open the .bin I just posted and can't get it to work. I have that tune in .cal and .tun (Tunercat and EFILive) but can't post either one of those formats on this forum. I removed the .bin from the previous post.
    Jeff
    Aug 2009
    Calibrating
    3,374
    Why not run the 4l60E segment with the relay mod? That what I do on my Fbody
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
