Going to be tuning a cobalt with GMS1.....anything different to do between that and a stock LNF?
have patients there are more limits set in the gms1 to protect the turbo. they did this to still be able to issue a warranty package with it. but to answer directly no they are the same.
I'll post once more that it is better to keep the stock LNF file and just input the 3 bar MAP sensor data. Less nannies you cannot access than the GMPP file.
'12 Camaro T3 2SS/RS LS3 M6, SLP TVS 2300, Flex Fuel
oh ok....are there any additional tables to alter besides DAL to increase the boost level??
a lot more....see torque management turbocharger settings lol
so if I was to want to go with the stock tune file, would I just have to flash with a stock tune file like a normal flash, or a write entire? And what would need to be changed to make use of the new map sensors? Thanks for the help!
Been posted a dozen times. Search for my posts on the 3 bar MAP tables. I don't have time to look it up right now. Maybe someone can link it for you.
