I suspect my ecm is bricked....was driving along about 25mph and engine stalled. got it running after a long ctank. was running rough and had to keep my foot all the way in it to keep it running and limped it to the house about 1/4 mile away. Could never get it to start again and would just backfire in the exhaust. It had a DTC for p0336 ckp sensor performance, so I installed a new crankshaft sensor. While installing it I stuck my finger in the hole and turned engine over by hand feeling the reluctor wheel and it feels tight and all the teeth feel good. Still engine does the same thing and code still comes back. Hooked up HP tuners and rpm signal intermittent. I checked harness and all is good but I ordered one and installed it anyway. Also borrowed the MAF and coils off my dads solstice and still no change. I had ECM connection come out and reprogram my ecm with the latest OS and updates. Engine doesnt throw the p0336 code anymore, but it will now start for a few seconds and quit. In my logs it seems everything is all over the place. Pulled injectors and rail out of the head but still hooked up, good strong spray pattern. Checked coils and all have good spark. ECM is the only thing left...Oh I did try to reflash it one night with voltage low enough to throw an p0606 code which I know is a no no, but forgot what I was doing at the time. But code never came back after a good charge. Here is my logs of it trying to start...tell me what you guys think.....Vats was also relinked when performing the reprogram
