Results 1 to 20 of 20
Thread: 2004 GTO 4L80E Segment swap????
    Mar 2007
    HOUSTON, TX
    32
    Has Hptuners figured this out yet? I'm looking at this harness that Speartech offers http://www.speartech.com/product_p/4l80eaddon.htm.
    Talking to Speartech they said Hptuners has a segment for ls cars but didn't know if they can do one for the GTO.
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    This specific topic was recently discussed in the thread below ...
    http://www.hptuners.com/forum/showthread.php?t=42070
    There is no available 4L80 segment to swap into the 2004 GTO OS.
    Corvette - no problem.
    Full-size truck / SUV / Van / S10 - no problem.
    GTO - a segment swap is not an option (as one does not exist).
    Nov 2006
    2,699
    You need one of these
    http://pcmofnc.com/index.php?option=...153&Itemid=106
    A GTO just went a 8.74 @ 156 with one of our harnesses!
    Tuner at PCMofnc.com
    Aug 2006
    Oak Forest, Ill.
    36
    I have a 2004 GTO 4L80e tune---But not in HPTuners format. I have it in Tunercat and EFIlive.
    Jeff
    98 GMC Twin Turbo 5.0, 4L80e, Moser 60, 4:10s,
    Nov 2011
    753
    Quote Originally Posted by Lextech View Post
    Jeff
    Guessing you used Tunercat to change the transmission type in the GTO tune - not the same process as a segment swap.
    EFILive doesn't seem to mind these changes. HPT will often display a "could not parse file" error when trying to open a tune file so modified, and in *.bin format.
    Aug 2006
    Oak Forest, Ill.
    36
    Quote Originally Posted by Shrek View Post
    I am not the guy who converted it. I have had it for several years, but have never had occasion to use it. If I recall correctly it was done by someone in Australia. I can flash this tune, I can read this tune and I can alter this tune. I have bench flashed it into a 12586242 PCM with Tunercat and then read it out in EFILive. It shows up as a 4L80 and shows the correct trans gear ratios so I am thinking it is legit. Anyone is welcome to try it out if they want.
    Jeff
    Aug 2006
    5BA8
    3,179
    Jeff
    Sounds like someone did a segment swap in hex. I'd like to look at it if you wanna email it to me. I've got both EFIlive and TC, so whichever you wanna send would be fine.
    EFI specialist
    email=[email protected]
    Mar 2007
    HOUSTON, TX
    32
    Ended up getting my TCI TCU box to work. I was exploring other options. However it is good to know it seems someone has made a swap but not hptuners
    O and Travis's GTO is a 05. Funny thing is this is Travis's old TCI box lol.
    Mar 2007
    HOUSTON, TX
    32
    Jeff can you email me that file please sir. [email protected]
    I wish Hptuners would use this data to make a fix.
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    Quote Originally Posted by 1INSANEGTO View Post
    What data? No files have been posted.
    If someone sent me one I could store it for future use.
    Aug 2006
    Oak Forest, Ill.
    36
    Bill, I will send it to you shortly. I don't have it in HPT format. I have it in Tunercat and EFILive. I HAVE NEVER used it but, I believe it to be legit. It would be great if someone could use/verify that it is a valid tune before it gets spread around.
    Jeff
    HP Tuners Support
    (foff667)
    28,261
    The only formats I can work with are .hpt or straight binary.
    Aug 2006
    Oak Forest, Ill.
    36
    I can flash an extra PCM with Tunercat. Let me see if I can find someone around me that can pull it in HPT.
    Jeff
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,859
    OP... Are you trying to do a 4L80 in a 05/06 GTO? If that's the case, there's no segment swapping. You just need the 4L80's controller hooked up with a transmission calibration already on it, then read the file out of the car. The transmission controller has it's own file as opposed to the 04 GTO where it's all done in the PCM.
    http://www.dsxtuning.com
    Just say no to bull s***.
    HP Tuners Support
    (foff667)
    28,261
    No 2004.
    Mar 2007
    HOUSTON, TX
    32
    Sent you the email bill.
    HP Tuners Support
    (foff667)
    28,261
    Yeah, not much we can do with efi or tunercat format files.
    Dec 2008
    on the Dyno
    1,825
    email sent Bill. Came across a file that appears to have some sort of different transmission and transmission diagnostic OS from all of the 60E tune files I have. See what you think of it.
    Located in Central Kentucky
    ShorTuning
    Apr 2009
    West Plains, Missouri, USA
    55
    I looked at the trans segment and trans diagnostic segment in binary and they are the same identical length in both the GTO and 2004 Truck O/S that is one digit different
    Truck OS 12587603
    GTO OS 12587604
    So I copied the two segments into the gto file, programmed a PCM, then read it back ... One in Binary, one with HP Tuners. I also used EFI Live and TC OBD2, but even in a .zip file this forum would not let me upload those.
    Binary
    HP Tuners
    This is UNTESTED, but I don't see why it won't work. The GTO file is otherwise stock, so make necessary adjustments....
    May 2018
    Florida
    44
    Sorry for bringing this back from the dead... but did the above file work?? I just downloaded, and it seems like the only file possible to use for a 4l80 swap in an 04 gto... THanks
