Results 1 to 13 of 13
Thread: Turbo Flutter
    Mar 2009
    6
    Turbo Flutter
    I have searched the forum on this issue and found that this may not be an issue to worry about. Mods: AEM CAI and catless down and HPT tuned. I only get this flutter at cruising speed on deceleration. After moderate to hard accleration, it sounds like I have an aftermarket B/V(normal). I notice when i use the stock intake tube (turbo to CAI pipe) this flutter is much quieter and almost nonexistant. I recently installed a ZZP upgraded intake tube on the AEM and noticed the flutter is louder than ever. I also noticed that that you can feel the car stumble when it does this (light accleration only). Moderate to hard acceleration the car runs flawless.
    Any thoughts would be welcome and thanks in advance.
    Senior Tuner Iam Broke's Avatar
    Jul 2009
    2,305
    Sounds like you need to work on your maf tuning. Excessive stft swings will cause the stumble. Pretty much the nature of the AEM intake as I recall. A lot of maf turbulence.
    Mar 2009
    6
    I will work on those thanks. I had read your post about your experience with AEM CAI. I just wanted to make sure I wasn't doing any harm to the turbo. It sound like AEM makes racing sounds lol!
    Dec 2008
    Nevada
    4,452
    i used to weld three tabs on the inside of the AEM intakes with a tigwelder after installing a 3" airflow straightener infront of the maf location. it would help with some of the turbulence and bouncing maf values.
    Mar 2009
    6
    I will work on my STFT first and go from there. I may just go to the air box mod and my zzp intake tube. Thanks for the input.
    Jul 2009
    2,305
    Quote Originally Posted by cobaltssoverbooster View Post
    I used a treadstone straightener on my custom Dejon, last one I settled on using a tapered coupler to the turbo instead of the rad hose sleeve it came with. lol.
    Cut a 3" straightener down just a bit to fit and rtv'd it in the tube 1/2" in front of the MAF. Really didn't see much different with or without the straightener though.
    Mar 2009
    6
    I might try modify the intake. I didn't spend a lot for it so if I mess it up, I won't be out much. I read somewhere that someone made a CAI out of PVC pipe lol!!!!!
    Mods: Stock air box mod/ ZZP intake tube
    ZZP catless DP
    3 bar maps and HP tuned
    KY Clutch stage 3
    Dec 2008
    Nevada
    4,452
    If u do that I hope they ban u for a month
    Mar 2009
    6
    I am from Kentucky. But I would never do that lol!!!!
    ZZP catless DP
    KY Clutch stage 3
    Dec 2008
    Nevada
    4,452
    look away from the darkness and come to the light of hpt forum knowledge
    lol ^
    Advanced Tuner projectlnf's Avatar
    Jun 2012
    warrenton va
    476
    Quote Originally Posted by bcuree View Post
    i have seen a full charge piping on a turbo honda made from pvc.. hey it worked! but lord have mercy it was stupid! lol the kid decided to bring this to me to tune it a while back and i poped the hood to see what was done just for my knowledge... low and behold a plumbers heaven.. i just shook my head and told him to get real charge piping and sent him on his way lol
    2003 Ford excursion 6.0 PSD
    No limit intake
    Straight pipe
    Studded
    EGR delete
    KC billet single plane compressor wheel
    Self Tuned
    XDP Regulated return
    RDP Fuel sump
    AEM progressive water meth
    Custom suspension air bags
    8" lift
    35" tires
    Mar 2009
    6
    Update
    I want to thank you Iam broke, the problem was solved after I removed the aem cai and preformed an air box mod. Car runs great and I am falling in love again lol!!!!!
    ZZP catless DP
    KY Clutch stage 3
