Page 15 of 15 FirstFirst ... 51112131415
Results 281 to 299 of 299
Thread: EQ <> VE Version 4
  1. #281
    Jun 2015
    TN
    189
    Using the built in editor I got fuel trims within 0 to 1%. When I put it back to MAF/VVE it runs like crap. unexplained surge while cruising. Bucking/surging on take off. I gave up on VVE. My ZL1 runs smooth as stock when running MAF only. I think the HPTuners VVE editor should be looked at by the powers that be, and improved upon if possible. My 2 cents.
    RPS Twin Carbon Clutch
    Kook's Headers
    Ported Supercharger
    Cold Air Inductions cai
    ID850's
    GPTuning 2.5 Cam
    9.1 Lower 2.5 Upper
  2. #282
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Have you logged VE, MAF and dynamic airflow to see what is going on?
  3. #283
    Jun 2015
    TN
    189
    I don't believe I was logging dynamic airflow ( mass air flow rate??) Should that be in a graph or just a channel to look at? You can look at the log if you like. VVE Tuning Rev 3.hpl
    Kook's Headers
    Ported Supercharger
    ID850's
    GPTuning 2.5 Cam
    9.1 Lower 2.5 Upper
  4. #284
    Advanced Tuner 4wheelinls1's Avatar
    Jun 2009
    Melbourne Australia
    284
    If you watch the commanded EQ while driving you will see some radical changes when the ecu switches from SD blended to filered MAF. I spent a week messing around with a cammed LSA GTS Commodore with driveability issues that has been to 2 other tuners, I tried MAFless and with MAF and utilizing the HP VE and it always had similar issues, bucking on WOT at low rpm as revving up due to a big change in calculated airflow. Eventually I went to the other guys and used the calculated VE as it back edits the stock coefficients and the car was fine, I picked up 2 more after that to fix with similar results. There is a difference in the airflows in the HP VE calculation to the factory Coefficients that differ too much from the MAF. I like the MAF as high speed timing and fuel is much more stable and i find I can make more power due to that with better driveability.
  5. #285
    Jul 2015
    Piedmont, SC
    13
    Hoping for a little direction here. Working a tune on a GMPP LS3 in a 67 Lemans. This is the first time I have tuned VVE, using Bluecats EQ<>VE version 4.2.2. Problem I am having is when trying to copy "Zone MAP Boundaries", I am just getting the red flash. I have tried the way it is said to be done, right click on button and copy. I also tried coping in the table page which has already been stated, wrong way. I am using the latest version of HPT and have tried deleting the VE program and downloading again twice. Same results. Also tried a totally different vehicle(08 H3, just to see if I could get past this point) with the same result. Zone RPM boundaries copies fine, green flash. I can manually copy paste but don't really want to have to put in all the constants manually if that will even work later on. Scratching my head, done hours of reading and haven't seen anyone with same issue or how to correct. I appreciate any advice.
  6. #286
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Just use the built in virtual VE editor. It's built into HPT now.
  7. #287
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    Yes use the buillt in editor. The "hooks" needed for the bluecat tool to automatically paste back in have been removed
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
  8. #288
    Tuning Addict
    6,802
    It's under Edit in the editor - just make sure yours is updated...
    ~Greg Huggins~
  9. #289
    Jul 2015
    Piedmont, SC
    13
    Thank you. I have used the editor before, just trying something different. I know, don't fix what isn't broke. (But we're hot rod car guys right...!)
  10. #290
    Mar 2015
    233
    I was about to spend the morning installing the necessary software (.net?) and hunting down the bluecat software to get started on my vve tuning. Are you saying with the latest version of HPT, I no longer need any 3rd party software to edit the VVE tables?
    I'm still on 3.0.
    2011 Camaro SS
    Thompson Motorsports Dart 427
    ESS Tuning G4 Supercharger 1158whp/1017wtq
    DSX Tuning stuff
  11. #291
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    3.0 has it too. Edit, virtual VE editor.
    I would move to latest version. If 3.0 is working then it should just be a quick upgrade to install 3.whatever the latest version is
  12. #292
    Mar 2015
    233
    Thanks. It's hard to keep up with this ever evolving collaboration of tuning software efforts. Especially when I only use it once in a while.
    So just create a histogram to plot AFR error against the same row and columns as the VVE table and tune as if I was tuning a 3rd gen VE table?
    I mean "graph", and it probably already exists.
    2011 Camaro SS
    DSX Tuning stuff
  13. #293
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Pretty much. You can change the axis headers in VVE editor to whatever you want them to be also.
    Also make sure you make the manifold switch open and closed tables the same. Only one is typically used but the one that opens by default oftentimes isn't the one that is used, a lot of people had issues with that in the beginning
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
  14. #294
    Sep 2008
    399
    when i right click copy zone map boundaries, it flashes red and does not proceed. Any Ideas?
  15. #295
    Jun 2015
    TN
    189
    Are you still trying to use bluecat?
    Kook's Headers
    Ported Supercharger
    ID850's
    GPTuning 2.5 Cam
    9.1 Lower 2.5 Upper
  16. #296
    Sep 2008
    399
    yes. mainly to see what kind of zone rpm and map boundaries it creates. Im not very good in that area.
  17. #297
    Jun 2015
    TN
    189
    You cant use bluecat with 3.0+
    There is a built in editor now. See Schpenxel's post above. Click Edit on the top left, then click virtual volumetric efficiency. It brings up a single table that makes many changes to several of those individual speed density tables. When you make a change, Click calculate coefficients, The other tables will then be magically changed based on this one table.
    Kook's Headers
    Ported Supercharger
    ID850's
    GPTuning 2.5 Cam
    9.1 Lower 2.5 Upper
  18. #298
    Sep 2008
    399
    I know this, but it doesn't provide any help with your boundaries. Which bluecat did
  19. #299
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Yeah, that is the only downside of HPT's built in VVE editor
    You will probably have to open each table individually and copy/paste them manually. The faster way of doing it doesn't work anymore. Honestly I haven't tried it at all in a while but that would be your best chance of success
