Results 1 to 7 of 7
Thread: 2bar not available for 06 E38 pcm?
    Feb 2013
    Huntington Beach CA
    6
    Why can't I upgrade the os in this file?
    28,273
    Because its an old operating system
    12614676 00005739 New software to correct battery run down condition.
    12611833 00007FA5 New software to correct a possible no start condition on first attempt after a battery disconnect.
    12608602 0000C139 Main Operating System
    Update to the newer 4676 operating system and 2 bar should be available.
    Feb 2020
    texas
    Question
    Hi, So what to do? There’s no way to upgrade? I?m in the same boat
    You can take your PCM to the dealership and they will upgrade it for you with their Tech2 device. I have no idea what that would cost but once it is loaded onto your PCM, HP Tuners can manipulate it. You might also find a copy of that recommended OS in the tune repository around here.
    Rick
    1970 Chevrolet El Camino LM7 5.3 liter mill and a 4L60E transmission.
    Arizona
    247
    Flash with a newer OS for 2 BAR OS availability. Might need to purchase an additional 2 credits.
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
    Senior Tuner mbray01's Avatar
    Dec 2013
    Slidell, La.
    1,015
    yep, write entire with updated os
    Michael Bray
    Rusty Knuckle Garage
    Slidell, Louisiana
    20yr Master Tech.
    Advanced Level Specialist
    GM World Class Technician
    Shop Owner
    Advanced Tuner Montecarlodrag's Avatar
    Nov 2009
    Pegasus Galaxy
    919
    Not a good idea to flash a newer OS to a E38 ECU using hpt, sometimes they brick because the new OS has an internal incompatibility between the segments 7 and 8 (which are not written by hptuners).
    The correct way is to flash it is using SPS, once completed read, license and flash normally.
    9 sec Montecarlo SS
