08 6.0 Max 92 mph is as fast as she goes what am I missing or what do I need to raise, lower, eliminate or get rid of to set it higher
well where is the tune posted so it can be looked at
2000 Firebird,2002 O.S.,LQ4 370,Borg Warner S475,truck mani.,Eagle crank,Callies Compstar Rods,Wiseco-11 4.030 pistons 9.4:1 comp.,LS3CNC heads,LS3 intake,NW92mm throttle body,ID1000 injectors,BTR trunion upgrade,LJMS STG3 cam,LS7 Lifters,ARP Studs-bolts,Frozen Boost A to W intercooler,JGS 60MM BOV,2 40mmJGS Wastegates,4L80E trans wth segment swap,CircleD 3400 single disk,MOSER 12 3.31gears ,BMR K-Mem.,2 Walboro 450 pumps,Returnstyle fuelsystem MAGNAFUEL regulator.
LS1Tech sig KRAZY K 2000 TA
you can do the changes under transmission, also make sure your tune is calibration and not GMLAN
98 Z28
stock ls1 engine,A4,Fast 90/90,SLP lid,Ms3 112LSA,LT Headers,TCI 3500stall,semens 60 inj,ASP under drive ,3.73 gear,11.82 1/4 .sold
Thanks guys it dont pay to get in a hurry
