Getting tired of fighting the FIC 72's at 4 bar. (60#/hr @ 3 bar) Questioned them on the data provided and although they say it is correct I had to rape the MAF over +20% to get the fueling in line. Commanded fuel pressure is ~67 psi at 9 lbs boost and it does drop to 60 at 6600 but that's not enough for the MAF rape. The positive skew is consistent through the mid to high boost range before the FP drops. IDC is peaking at 84% at .80 lambda on E35 so I believe they are 72# injectors at 4 bar but no way to tell here.
Posting from work so no log or tune but I was about 3-4% positive on the MAF cal vs stock with the K&N & SLP TVS on SLP's 52's before maxing the injectors out.
My question is will the ID 850's require a scale in the tune? Never did that before and iDK how complicated it becomes.
Thanks!
