I downloaded the new 2.24 update the other day but since then every time I open up my editor or scanner it wants me to enter my application key. How do I fix this?
close all programs
open vcm editor
enter your app key
commit
close vcm editor
done.
I have the same issue. It does not do this on my laptop running Win Vista. However, it does not store the application key on my new computer running Win 8. I have tried as you have instructed several times. Any other suggestions?
Blackcoupe are you sure you aren't running 8.1? MS made alot of changes in 8.1 and apparently whatever changes they've made also effect the app key as you've described.
I have the same problem. I have Windows-7 and tried as you said with loading the App key and closing the program. It did not work. I still have to reenter my App key every time I open the program. Any other suggestions.
Ken
Same prob, windows 7 pro. there's no commit button, just an ok button
01 Blazer L31 350, 0411control. 00 Blazer built 383, 0411 control. Neither run right yet! Help!!!
Have you tried running the VCM Editor as an administrator ?
No matter what the question is, the answer is always MORE HORSEPOWER!!
Bill any idea of when this issue might be fixed?
Ken
Have you emailed support?
It was fixed a week or so ago. Everyone that emailed support got taken care of.
You might want to check because you actually went in and looked at my computer on Tue. the 26 and said you were going to turn it over to support. I have not recieved any response so far.
Ken
Ok, the fix is simple, redownload & install 2.24 from your customer page.
