Results 1 to 13 of 13
Thread: logging over 104.4 kpa on 2 bar os
    Mar 2013
    35
    I cant seem to figure out how to log kpa over 104.4? I've tried manifold air pressure and the 2 bar map pid. kpa just stops at 104.4. I'm using the dpe 2.5 bar, if some one could point me in the right direction that would be great!
    Tuner 07MontRedcp's Avatar
    Jan 2007
    Arizona
    187
    You didn't mention it so I have to ask. Did you remember to change the map offset and slope values?
    BJK
    APS TT 630 rwhp/654 rwtq @ 9 psi
    '07 C6, TR6060 conversion w/Z06 ratios. DTE Stage 4 Quaife Diff w/brace (3.73). Z06 Brakes, mild turbo cam & dual springs (222/222, LSA 115, .581/.581), LS9R clutch, LG GT2 Coilovers, Autometer Cobalt Fuel gauage, Progressive Alky Controller, and e-Boost2 Controller. PFADT poly bushing for control arms and Sports sway bars. MGW shifter. 3" B&B Fusion. RSI Stage 1.5 fuel system. RX dual valve catch can.
    Jan 2007
    LOS ANGELES
    81
    Make sure to delete the maf pid ......
    07montredcp
    How you been Bruce ... Its Gev
    Jan 2007
    Arizona
    187
    Hey Gev, I didn't know you frequented this forum. What are you up to these days?
    BJK
    Mar 2013
    35
    Quote Originally Posted by HyeSpeeder View Post
    07montredcp
    Tried no dice!
    Mar 2013
    35
    Quote Originally Posted by 07MontRedcp View Post
    BJK
    of course car runs great, I just cant reference where I'm at on the boost map
    Mar 2013
    35
    what pid am I looking for and where is it?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,261
    There is no 2 bar map pid for gen 4 applications I'm wondering what exactly you are logging. A brief scanner log would be helpful.
    Mar 2013
    35
    here ya go!
    HP Tuners Support
    (foff667)
    28,261
    Ok post your current .hpt file
    Mar 2013
    35
    here it is , thanks
    HP Tuners Support
    (foff667)
    28,261
    map sensor linear B looks wrong but everything eles(at a quick glance)appears to be ok.
    Try setting that constant correctly & try again.
    If it still doesn't work log the map voltage so you can see what the map sensor is actually reporting, this should help give you an idea if the map sensor is the issue(which is what I'm leaning toward at this point).
    Mar 2013
    35
    I loaded afr x ve boost histogram along with manifold air pressure and (SAE)manifold absolute pressure PIDs in the table display and now it works? do you just divide 244.68kpa by 3 to get your linear b? thanks for your time!
